Question about Sanyo PLC-WXU300 Bulb/Lamp
Wont turn on
Plugged in and worn turn on
Farm pro raider(Homier)
Only thing left is compression. Stuck valves will affect compression as well as worn rings.
Jan 23, 2014 | Peg Perego John Deere Farm Tractor and...
Truck wont start
Check for spark at the distributor if no spark check or replace coil pack. also check to see distributor is turning while engine cranking, if not, possible worn out or broken gear tooth on shaft inside engine.
if distributor turns, check for burnt or worn out points and/or contacts on distributor cap.
Dec 27, 2013 | 1986 Ford Ranger 2WD
Wont start 1995 530 bmw
engine could need tune up.could have faulty engine coolant temperature sensor.could have clogged fuel filter and air filter.could have worn out spark plugs and wires.faulty rotor and distributor cap. ignition timing off could have worn or broken timing belt.many things will cause no start.first code scan vechicle first before buying new parts.
Dec 20, 2012 | 1995 BMW 5 Series
Hi , i have a 01 altima , 2.4 liter, it will not fire , just turns over , wont start. i changed the crankshaft position sensor, still wont start, any ideas?
dont become a parts replacer-u cud stall urself--get car scanned or chec underhood for any changes like noises,bad wires... u may hav a failin gas pump or pressure regulator--cud hav worn plug wires or dist/module
Aug 24, 2010 | Nissan Altima Cars & Trucks
Why is my malibu 200 watts transformer not working, the timer will set off the lights but then not turn them off, then the next day they wont come on but when I rotate the dial they come on? Frank
Tripper might be worn down and not pushing switch.
Switch might be broken or worn down.
Improvise by setting timer to override and plug power into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 31, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Car turns over wont fire 1994 saturn sl
Feels Like Change Symptom: No Start Change When: Ignition Key On Change Where: Engine Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 2 Inspect Battery Battery Discharged or Faulty. 3 Inspect Battery Cable Coroded, Broken, Shorted or Poorly Connected Battery Cable. 4 Inspect Solenoid Switch Starter Solenoid Switch Faulty. 5 Inspect Starter Starter Motor Faulty. 6 Inspect Wireset Worn or Damaged Spark Plug Wires. 7 Inspect Coil -Ignition- Faulty Ignition Coil. 8 Inspect Distributor Cap Loose, Cracked or Worn Distributor Cap. 9 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 10 Inspect Distributor Cap and Rotor Kit Loose, Cracked or Worn Distributor Cap. 11 Inspect Fuel Tank Fuel Tank Empty. 12 Inspect Carburetor Worn, Faulty or Damaged Carburetor. 13 Inspect Fuel Pump Faulty Fuel Pump.
Sep 06, 2009 | 1994 Saturn Sl
Lighter plug wont work no blown fuse
sometimes there is a seperate fuse for just the lighter in the wiring behind the lighter socket you will have to either remove the socket or find the wiring under the dash to see if their is a fuse and replace it if it is worn or even possibly the connections to the socket have worn or become disconnected
Sep 03, 2009 | Mazda Protege Cars & Trucks
Wont start turns over but no start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
Jul 02, 2009 | 1997 Ford F250 SuperCab
I try starting the car but it wont turn over
1 Inspect Battery Damaged or faulty battery and/or connections. grey_line.gif 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. grey_line.gif 3 Inspect Fuel Filter Clogged or dirty fuel filter grey_line.gif 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. grey_line.gif 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. grey_line.gif 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). grey_line.gif 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. grey_line.gif 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. grey_line.gif 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. grey_line.gif 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. grey_line.gif 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. grey_line.gif 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. grey_line.gif 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. grey_line.gif 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. grey_line.gif 15 Inspect Distributor Cap Loose or cracked distributor cap grey_line.gif 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. grey_line.gif 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. grey_line.gif 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. grey_line.gif 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. grey_line.gif 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). grey_line.gif 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). grey_line.gif 22 Inspect Timing Belt Slipped or broken timing belt. grey_line.gif 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). grey_line.gif 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. grey_line.gif 25 Inspect Ignition Timing Incorrectly adjusted engine timing. grey_line.gif
Dec 02, 2008 | 1999 Chevrolet Cavalier
Sanyo PLC-WXU300 Bulb/Lamp Logo
20 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
