Question about Ztech Aluminum Pull Cart
Bag support broken
Need replacement part
Stella McCartney bag repair. I live in Chicago and wanted to know if there is a reputable (or preferably authorized) Stella repair shop or I need to send it away. Thank you!!!
Hi,we have designer bags repair parts on sale,you can try replace the broken yourself.
http://www.orderswithin.com/repair-and-replacement-c-529.html
Sep 17, 2013 | Cars & Trucks
How to replace wheels on hartmann garment bag
Some wheels are attached to the bags through screw or bolts, which are securing hardware and easy to remove. When such wheels need replacement, you can replace them by yourself. Some are attached to the bags through rivets, which require you to ask for professional removal and repairing service in case that they are broken. Some wheels of rolling garment bags can't be removed and replaced.
Aug 21, 2012 | Cars & Trucks
Why does my air bag light stay on I have a yukon denali 2003
If it is on, you probably have a broken clock spring-it will need to be replaced to have airbag functions again.
May 23, 2011 | 2003 GMC Yukon Denali
LSAYS I NEED NEW BAG, PUT IN NEW BAG & STILL LIGHT WILL NOT GO OUT & VACUUM WILL NOT TURN ON
Although this generally indicates that the bag is full, it may be caused by other problems. If you have fine dust in your area, the bag may seem like it's not full, but the pores in the bag are clogged so the vacuum will shut off as if the bag is full. This can be partially solved by setting the dial on top to the smallest dot.
The problem could also be caused by a dirty afterfilter. This filter is located beneath the tool caddy on the back of the machine. Access is gained by pressing the tab on the back of the machine and lifting the caddy. If dirty, replace it. If you don't have a replacement, check to see if the vacuum will run without it. It should if there is not other problem causing the vacuum to not run.
Third, try detaching the hose, turn the machine on to see if it runs. If it does, place your hand over the in port. If the vacuum shuts off, the problem is most likely a broken, worn, or clogged Control Valve Assembly. This is the part the dial connects to. This is a problem that should only be repaired by an authorized Aerus Electrolux service tech. If you have been using generic "Made to fit Electrolux" bags, the motor and interior of the machine should be cleaned. This is worth doing as there should be a long "life" ahead for the vacuum. Periodic maintenance should be done.
You can find the nearest store using the below link.
It could also be caused by loose connections, worn or broken switch/es, broken wires, or bad motor. This can be narrowed down at the shop.
http://www.aerushome.com/storelocator/
Dec 12, 2010 | Electrolux Epic 6500 Vacuum
The handle of my lugguage bag was broken. where do I get it repair or replacement of the part. thanks
If it is the pull out handle that has broken this is a common problem with this bag. No spare parts are available im afraid.. If it is still under guarantee take it back.
Sep 24, 2010 | Akona Evolution Roller Free Reg Bag ...
Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
Mar 05, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My kriby micron magic vac is not picking up .
There are several reasons why your Kirby isn't performing at it's best.Check the fill tube inside the cloth bag for clogs or tears in the fill tube itself.If the cloth bag is full of dirt,you have a broken or loose filltube.Check to see if the belt needs to be replaced.The belt could be streched out or broken.Next,check to see if the bristles on the brusroll are wore down.You could need a new brushroll.If the brushroll is resonably new,it could need to be adjusted down more.To adjust the brushroll.remove it from the housing and turn the ends of the brushroll to the next side,and reinstall.The ends of the brushroll are equipped with offset end,and by turning the ends and dropping it back in,you've adjusted it to the next level.The bristles should extend 1/8-1/4 inch beyond rug plate.Also if theres dirt in the cloth bag,you may have to wash bag to clean out the pores in the cloth.
Oct 27, 2008 | Kirby Vacuums
Ztech Aluminum Pull Cart Logo
65 people viewed this question
Top Ztech Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Ztech Golf Expert? Answer questions, earn points and help others
