Question about Nextar Q3 GPS Receiver
My nextar 14-bc gps unit won't power up. It worked fine for a while, then when it needed a recharge I plugged it in, both through the wall charger and the cig lighter adapter ( which blew out fuses in my car). Now it won't come on at all
SOURCE: Product registration for my new Nextar GPS unit
I had the same issue with the website. If you live in the U.S. call 1-888-849-0846 and they will do it over the phone. You must have your Serial number to register it.
Posted on Feb 10, 2009
SOURCE: nextar X-11-15302 or P3
A generic 12 volt adapter should work. I replaced mine recently. They usually come with multiple sizes of round ends and can adjust the output voltage. The side of the device will tell you the polarity and the voltage required. If it says something like 5 V but the adapter only has 4.5 V or 6 V, select the closer choice. If they're about equal, select the lower one. It is better to have an under volt than an over volt.
Posted on Mar 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: finding the reset hole on the nextar I4-Bc
PDF] I4-BC Hardware Manual.pdf 2345k - Adobe PDF - View as html Global Positioning System ("GPS") hardware, operating software or other aspects of this ... outlet again to reset the player. If the problems still exist, ...www.nextar.com/images/Product/I4-BC Hardware Manual.pdf
Posted on Aug 16, 2009
  • 589 Answers
SOURCE: Garmin GTM 25 Charger is
Unscew the Cig lighter plug silver or black tip part, the fuse in located in there, be careful its sping loaded....check fuse should be a 3 A fuse any Radio Shack should have it or auto store
Posted on Oct 23, 2010
SOURCE: NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Posted on Dec 03, 2010
My nextar 14-bct was not on for a long time then I charged battery a short time then when I was playing with it in house it went blank and now will not turn on
I have a nextar 14-bc and I was having similar problem and I found that the power in jack had a broken solder joint and when I thought it was charging it was not. I would not turn on until I discovered the broken solder joint inside on the power jack. I resoldered it and after it charged up it was up and working again. You might check on that.
Aug 19, 2011 | Nextar I4-BC GPS Receiver
Hi, my gps nextar x3i-02 is not turning on, what can I do?
The problem with your nextar is either the battery or the charger is faulty. Either ways you need to test them both then replace the faulty part. That is why the gps receiver is not powering up.
Do not panic when your gps seems to be acting funny, There is no problem without a solution, and if it is beyond repair the solution will simply be that you replace the gps receiver.
Solution:
  1. Test the battery in another gps receiver, to see if it will power it on,
  2. Charge the battery in another gps receiver for about 2 hours with another charger then try to power it on,
  3. If it turns on, then it means the battery is okay and working fine, but if it does not turn on the other gps, then it means the battery is bad and need to be replaced.
Solution:
  1. Test the charger on another gps receiver to see if it will work.
  2. If it does not work then you need to replace it,
  3. But if it works then you do not need to replace it.
After carrying out the test, you will be able to detect the problem and solve it.
Hope this information helped.
Dec 23, 2010 | Nextar X3-02 GPS Receiver
Battery doesnt stay charged like it used to ? approx three years old , works ok with charger plugged in
The battery has come to the end of its service life, you will need to replace the battery. Contact Nextar at www.nextar.com for information.
Jun 17, 2010 | Nextar I4-BC GPS Receiver
Finding the reset hole on the nextar I4-Bc
Aug 15, 2009 | Nextar I4-BC GPS Receiver
Gps dosen't hold a charge. ac power charge, or mobil charge
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
Jun 06, 2009 | Nextar Q3 GPS Receiver
Feb 23, 2009 | Nextar I4-BC GPS Receiver
Dont understand my gps
There are updates for a 14-BC is hat what you are looking for? If so follow the link. Hope this works!!!
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=I4-BC&subpr=&categ=
Jan 25, 2009 | Nextar I4-BC GPS Receiver
Unable to type in destination
Just recharge your battery using AC or car adapter.
Jan 23, 2009 | Nextar Q4-04 Car GPS Receiver
Nextar Q3 GPS Receiver Logo
306 people viewed this question
Top Nextar GPS Experts
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
