Question about RIM BlackBerry Pearl 8100
Change from c to f temperature reading ultrasonic clock
Change celus to farenihight
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
I can't see how to change for C to F temperature. Something happened when I put in new batteries.
Can't see much in the photo, but in general, push the "SET" button repeatedly to scroll though all the settings. Temperature UP and DOWN arrows change the settings when the display is flashing. Press "RUN" to lock it all in. Hope this helps.
Dec 13, 2013 | SkyScan Atomic Clock with Outdoor...
How to change temiture scale?
What make and model device?
Or are you asking in general? To convert from C to F, multiply by 1.8 and add 32.
Jul 01, 2013 | Audio Players & Recorders
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Ultrasonic flow meter to be used for multiproduct
CANT ANSWER QUESTION NEED TO BE SPECIFIC.WHAT ARE YOU WORKING ON.
May 18, 2010 | 1999 Oldsmobile Alero
When i turn oven on there is a code that said f10 what does this
Could be a defective temperature probe.
Test the probe by removing the wires. Take a VOM set for ohms. read the violet color wires for plus or minus 5% of 1100 ohms. If it reads OK at this resistance change out the ERC (clock). If it reads outside this resistance, change the temperature probe.
May 24, 2009 | Frigidaire FEB27S5A Electric Single Oven
Outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Apr 21, 2008 | SkyScan 86742 Digital Atomic Wall Clock
RIM BlackBerry  Pearl  8100 Logo
22 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
