Question about Seiko SZZC40 Watch
Battery for SZZC40
Part number of battery
Battery size for relic watch. On the back it says ZR11586 then *300210.
Christopher, Neither of these is a battery number. Open the watch and remove the battery. (Gently.) Copy the number(s) on the battery, using a magnifying lens if necessary.
Log onto eBay and search for "[the number] battery". Example: AG10 battery. I've never found one yet that was not available. And they are quite inexpensive--I usually buy more than one.
Apr 03, 2017 | Relic Watches
Need battery number for Seiko vivace ladies watch no 440180
  • Remove back
  • Locate battery and note installation details.
  • Identify type (number)
  • Obtain replacement battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Pay a jeweler a few bucks to replace it
Oct 25, 2016 | Seiko Watches
What number battery do I need for my Festina 7133 mens watch
Maybe a jeweler can try some trial-and-error to find something that will work.
Sep 02, 2016 | Festina Watches
Which battery number should I use on a bulova 96t63
Most likely...
Bulova 228 = S05 American Watch institute, USA: 357 (303)
Japan: SR44W .. (SR44SW)
Possibly...
Bulova 606‎ = S32 AWI... Energizer/Duracell 377 or SR626SW
Which battery number may use in this watch bulova 96t63 thanks
and
Specialty Battery Finder
Jul 28, 2016 | Bulova Crystal Ladies 96T63"
Mingrui 8547074 - what is the battery number?
Just take it to a local jeweller. They have all the batteries and will change it whilst you wait for between $4 and $8. Just not worth sourcing and having to buy 10.
If you really want to, the number is on the battery itself, so you have to open the back and remove the battery. You will need a jewellers eyeglass to read the number, so you have to buy one of those first.
Apr 29, 2016 | Watches
How do I change my battery in my nixon 51-30chrono stainless watch
Where the back contacts the watch you'll discover a spot where the back doesn't completely contact the watch case. Slide a thin bladed knife in there to pry off the back. You may see a screw holding the battery down. A jewelers screw driver will be needed to loosen it. You will see a number on the battery. The replacement battery will have the same number on it or a series of numbers it's compatible with. Once the battery is out, replacing it is simple.
Jan 01, 2016 | Nixon Watches
Can't find the battery number
The battery type and number should be listed in the owners guide that came with watch. If that's missing the battery type is printed on the battery.
Nov 06, 2010 | Tommy Bahama Rlx1004 Relax Beach Cruiser...
Battery problem
Stop panicking, please. If you lost the battery, that means your watch has been opened, so, read the movement number and submit here. Then Ill be able to give exact battery number.
Apr 14, 2010 | Pulsar Expansion PPH520 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Seiko SZZC40 Watch Logo
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
