Question about Fellowes P500-2 Shredder
Auto off-switch does not work
Auto off switch does not work
Auto Down window feature stopped working. Any ideas?
Try calibrating first,window up & hold switch for 3-4 seconds window down hold 3-4 seconds then back up & hold 3-4 seconds,check for the auto down to work if not then most likely the master switch is needed.
Oct 10, 2015 | Chrysler PT Cruiser Cars & Trucks
I have a 96' jeep grand cherokee laredo the head light switch in it is w/o fog lamp and w/o auto headlight can i switch it to one that has auto headlaight
r u trying to figure out if you install the auto headlight switch that you will have auto headlights, of just if the different switch will work period? there is probably a module required to make auto headlamps work, not just a switch. I would probably just find the correct switch for the truck to avoid any issues
Apr 24, 2014 | Cars & Trucks
Question about auto 4wd on my 99 GMC Jimmy
no not normal. check center of firewall the is a switch with 3 vacuum line CHECK THEM ALL this is your 4wd selector. if thats okay you might need the switch on the front trasfer case about $20 just unscrews easy fix.
Dec 25, 2013 | 1999 GMC Jimmy
Power window
Sounds like a passenger switch malfunction.
Sep 08, 2013 | 2009 Mazda CX-9
Asus 19inch LCD monitor keeps auto adjusting and turn off after 2secs. . i do reset it . . nothing happens. .it keeps auto adjusting itself repeatedly . . pls help me
The Auto knob maybe mechanically stuck or the internal switch may be defective. Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement. Do rate the solution.
Samir
Feb 07, 2011 | ASUS 19 Inch Sxga 1280X1024, 5MS,...
Unit starts with auto throttle off. engaging auto throttle shuts down unit. in past months, pluging in a cord would shut down unit. That is with no tool in use, just plugging into the receptacle.
Hi. There are 2 things that control the Auto Throttle and that is the idle control valve (Connected with black and yellow wires) and the Auto Throttle Unit.
Start Generator
Check for 12VDC on the Yellow wire of the idle control valve. Yellow is positive to any good Chassis ground. If you don't have 12VDC then either the Auto Throttle switch is bad or the Auto Throttle Unit iself.
You can gain access to the Auto throttle switch and again check for 12VDC to Ground on both sides of the switch with the switch on. (It may read as high as 13.8 engine running) If you don't get 12 - 13.8 VDC the the Auto throttle control unit is bad
If you have 12VDC to the Idle control Valve and it does not work perform a resistance check across the coil of the Idle control Valve (both wires disconnected Engine off) Black to yellow should read 3 to 4 Ohms If you have no resistance then the coil in the Idle control Valve is bad.
If you need more help just respond here
Kelly
Feb 09, 2010 | Honda 3000 Watt Portable Generator
Auto up/down driver's side window of 07 Sonata
pwr windows have no connection with the ecu. The switch is probably worn internally and will cause this issue, replace the switch if necessary. Hopefully this helps
Aug 12, 2009 | 2006 Hyundai Sonata
JVC camcorder won't work inside at night anymore.
check the following in camera mode and the auto/manual switch set to manual:
exposure: set to auto shutter: set to auto or off agc: auto white balance: auto program ae: off gain up: auto display/bright: +1-+3
after all that, hit the auto/manual switch again to set the camera into auto mode, the new settings should sort you out.
Jul 28, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Automatic windows
need to seset the window motor
Jun 18, 2008 | 2004 Infiniti G35 Sport Coupe
Fellowes P500-2 Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
