Question about Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830
Oil coming out of ohv cover
Smoke coming from left side of ohv cover. just started up for first time this spring.
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Overfill oil
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Leaking valve seal
smoke doesnt necessarily mean the valve seal is bad, check the valve cover breather. sometimes they plug up and **** oil up from motor. start it up and watch inside of carb for oil dripping.
Jul 16, 2012 | Honda Horizontal OHV Engine 50cc, GX...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
My 24 hp Briggs v twin smokes and uses oil bad. Smoke comes out of the left side when running. Can I use head gasket sealer to get me through the season?
There is no sealer that will resolve a head gasket issue, if that is what you have going on. and, if the head gasket failed remember it is a victim and not the cause, something else in happening.
I suspect that you have a compression related failure, based on the oil consumption and the smoke is probably blow by. This issue requires surgery to diagnose and fix.
Oct 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
White smoke out of exhaust on start up. what is the cause and the fix?
Really light smoke often appears blue. That light blue smoke as well as white smoke is oil smoke. (That is why some people will insist that oil smoke is blue...)
That is oil that has seeped into the combustion process. That most often is valve-stem seals/valve guides. The oil under the valve covers on top of the heads runs down the valve stem as the engine sits. (It is pretty unlikely that oil would seep up, past the rings...)
If that is the case, removing the heads and having the valve guides really fixed is the best solution.
You can inspect this problem without that level of disassembly, though.
After removing the valve covers and spark plugs.
Turn the engine to get a piston near TDC (but not quite at TDC). You don't want the vale to be able to drop into the cylinder, but you want a little room between the valve and the piston top.
There is a type of valve spring compressor that has a pair of prongs that grip the spring, with a hand-wheel on top to push down on the retainer.
Use a valve spring compressor like that to remove the valve-spring-retainer keepers, the valve-spring retainer and the valve spring(s) from 1 valve. Check the side to side play to see how the guide is. Check the condition of the seal. Check all the valves this way, unless you find right away that there is enough wear that rebuilding and reconditioning the head is necessary.
Jul 06, 2010 | 2002 Ford Expedition
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830 Logo
14 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
