Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Why isn't rinse aid dispenser working?
Cutlery coming out smeary and smears on dishes
    Master:
  • Zanussi Master
  • 753 Answers
Too much soap use less soap
Posted on Feb 06, 2016
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Our dishes are not being cleaned well with residue left on plates and cutlery and the light next to the rise aid is on at the end of the wash
I have had the same problem a time or two. Make sure that you don't overload the dishwasher and nothing is blocking the spout where the water comes out. Also if you haven't done so already, you may want to add some detergent to the pre wash. Make sure you have enough detergent for the regular wash cycle also....Hottest water possible (at least 140 degrees F). If all that doesn't help, try cleaning them on heavy wash. Check to make sure the rinse aid level is still full. I have also found it easier if you rinse the dishes or cutlery off before putting them into the dishwasher.If none of the suggestions work I say changing your dishwashing detergent and/or rinse aid.Good Luck!
Sep 08, 2011 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
DISHES ARE COMING OUT OF CLEANING CYCLE WITH A FILM ON THEM.
If this is a greasy film it may be your dishwasher needs a cleaning agent run through it This is a dishwasher cleaning product which you run through the maschine ON ITS OWN.If the film is smeary it could be too much rinse aid in the mix or excessive salt
Jan 30, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    My dishes come out dirtier looking after washing in the machine.
    check the water temperature is reach the desired setting,clean the rinse arm and check the rinse soaf if working at end of wash cycle.
    Jun 05, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
    Hello. My dishwasher has been pretty perfect for four years. When my house water softener ran out of salt, I added rinse aid and salt to the dishwasher for the first time. I subsequently added salt to the...
    Try cleaning the machine by adding white vinegar to the wash water (before the water-fill procedure finishes). Put your stained dishes and cutlery in with the wash to remove the hard water deposits. The combination of salt and rinse aid may have helped cause this problem. Hope this helps!
    Feb 11, 2010 | Dishwashers
    The rinse agent light is on and the water will not spray out
    NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
    Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    Cloudy glassware, stained flatware
    The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
    Jan 19, 2009 | Maytag 24 in. DWB1000 Built-in Dishwasher
    Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
    60 people viewed this question
    Top Zanussi Dishwashers Experts
    Paul Carew
    Charles T Nevin
    Charles T Nevin
    Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
