Question about Lifeguard Systems Health & Beauty
My lifeguard breathalyzer keeps turning on and off on its own?
I start it and as soon as I tip it up to blow, it shuts off until I hold it horizontally again.
5 Suggested Answers
  • 478 Answers
SOURCE: Fan blows high speed and computer wont start
How long havew you had the present motherboard in your computer? if over 3 years (and used on a dayly basies more then likely, your motherboard is in need of replacment because the capasitor/s are leaking (not giving the proper voltage to start and hold your computer at proper levels
Posted on Jan 14, 2010
mrhappyface
  • 205 Answers
SOURCE: model hl410100 the compresser works
might be a bad check valve and do nut use an extension cord ever on a air compressor it will over time damage the motor plug it in directly and use longer hose
Posted on Jul 07, 2011
teds_repairs
  • 2101 Answers
SOURCE: 2007 saturn ion transmission keeps blowing
are there any codes
Posted on Nov 28, 2012
  • 40820 Answers
SOURCE: My 2000 Ram 2500 AC blows cold until I step on the breaks. As soon as I break it starts blowing real hot. Starts cold again after I turn it off and turn it back on. Break again, it blows hot again
check for a fault in the climate control module that is affected by a power surge/ depletion from the brake circuit. It would appear that the ac compressor is being switched off by the fault and switches on again when you recycle the switch( could be a relay to the ac compressor.)
Posted on Jan 20, 2015
Keeps blowing auto shut down fuse as soon as key is turned on
Could be several things including one of the oxygen sensors, one of the injectors, the coils, or the engine computer.
You will probably need to get a shop manual to get all of the wiring diagrams connected with that circuit. And I would suggest you use a circuit breaker to check each one instead of fuses.
You'll have to disconnect each component until you find the short.
Oct 18, 2015 | 2004 Chrysler Town and Country
The Breathalyzer was wrong and i was kept an hour waiting
Did you use any alcoholic mouthwash? Sometimes the breathalyzer detects alcohol in the breath that has nothing to do with alveolar air. Instead of detecting the alcohol that comes up with air from the lungs, after having been absorbed through stomac and intestines and carried around through blood, the breathalyzer detects the alcohol that sits in the aesofagus or in the throat and mouth, either brought up with a burp or deposited from a mouthwash. Therefore the level of alcohol in these two instances is much higher than if an alcoholic drink were ingested, and therefore the officers have to make sure to keep an eye on the suspect to understand if there is in fact too much alcohol in his or her system or if it's a mistake made by their tool.
Jan 06, 2014 | Health & Beauty
Can i buy a breathalyzer to keep track of my drinking when i have to drive?
Yes and No. You can buy your own breathalyzer but it's not a good idea to rely on it.
Breathalyzers can be bought for personal use but these and the ones used for law enforcement do not provide the same accuracy. While the ones that the officers use are approved by the National Highway Traffic Safety Administration and can be faulty sometimes, but provide a more accurate result to BAC (blood alcohol content), the ones that are sold to the public are approved by the FDA and are much less accurate. It is not a good idea to rely on their results as they might lead you to thinking you can drive while instead you drank too much.
Sputtering while driving and running funny.
It could be a clogged fuel filter or you could have a old gas coated inside the carbrator. Seafoam will fix that up in a hurry. Don't be supprised if it blows smoke its cleaning all the junk bout of your carbrator. I would start with the simpelist things first. Fuel filter Check your carbrator Throttle adjustment Fuel pump relay Defiantly get a Haynes manual it will trouble shoot you through your problem.
Oct 30, 2013 | Nissan Hardbody Cars & Trucks
Model hl410100 the compresser works well until the pressure reaches about 75lb then the motor stops but keeps trying to turn as soon as you bleed off some air the motor starts again until it hits 75lb.It...
Jul 06, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 01, 2011 | Sony Computers & Internet
Jan 14, 2010 | Dell Optiplex GX280 (99301) Motherboard
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
2002 Jeep chrokee
Verify fuse is correct size, then see what you are turning on else when it blows. Fuel pumps are designed to pump up then shut off, until needed when starting and running. It might not be shutting off and staying running when vehicle is not running. Make sure ground circuit is in good shape and positive side as well. Does this blow fuses when you go to start, or does it start and run for awhile then blow?
May 14, 2008 | 2002 Jeep Grand Cherokee
Health & Beauty Logo
335 people viewed this question
Top Lifeguard Systems Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Lifeguard Systems Health and Beauty Expert? Answer questions, earn points and help others
