Question about Winter Sports
Polaris Indy 340 has barely any power
When I try to take off, I have to open it full throttle and I barely move the sled. I tried changing the plugs it did help a little but it just went back to same problem.
    Filmmaker:
    Uploaded 5 video answers.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Check your compression to see where you are. if it is too low you may need new rings or even bore your cylinder and new piston and rings.
that is where i would start
Posted on Jul 29, 2014
Torque specs
PDF]Engines - Vintage Snow
www.vintagesnow.com/Polaris_files/85%20engines.pdf
ENGINES. Engine Specifications. 1985 . .... Torque Specifications . .... Indy Sport. EC34-2PM-03. 339. 62. Indy Trail (All). EC50PM-01/02. 488. 72 .... 1989 Models ......Polaris snowmobiles are equipped with dependable, high-performance two.
Jan 13, 2016 | Winter Sports
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Had the seat recovered on my sled(tank/seat combo) and now cant get fuel from tank.sled fires up when fuel poured into cylinders but then dies when fuel is burnt off.sled is a 97 indy sport 440
take the fuel line from tank to fuel pump off the fuel pump blow air threw it and check for blockages no blockages? now the line from pump to carbs no blockages? rebuild the fuel pump cheap easy 20-30 dollars on ebay for the rebuild kit.
Feb 04, 2011 | Polaris ATV
I have a 1995 Polaris Indy 500. The engine floods out immediately. Once so bad yet a friend was going to borrow my machine it was running out of the exhaust pipe. If the plugs are dry, you get one pop...
this is caused by a stuck float in the carburetor. remove the carb from the machine, remove the float bowl from the carb, using carb cleaner - spray the components down and clean out any debris, make sure all parts move smooth and seals are clean, clear and not cracked,, re-assemble the unit and install back onto the sled. this will stop the constant flow of fuel.
have fun out in the snow --- ride on !!!
c...
Jan 07, 2011 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500, it won't start unless I hold the throttle wide open, it won't idle
THE THROTTLE SAFETY SWITCH IS NOT WORKING, YOU CAN EITHER CUT THE WIRES OR REPLACE THE SWITCH. I SUGEST REPLACING THE SWITCH
Dec 13, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a polaris 2009 600 IQ shift snowmobile that I would like to put a 12 volt dc plug on for my GPS. I got a outlet from polaris and I found the acc plug on the sled.I do not have electric start so...
I Have a 2010 Polaris Shift (with No electric start) and over the clutch on the left side (sitting on the sled) is a bunch of plugs, one with 4 wires.. and a longer plug with even more wires.... The One with 4 wires has a Yellow wire that produces about 10V AC, which is a good tap for a electric shield. The Longer plug has a solid Red wire which produces around 13.5V DC, which is a good tap for your 12V Plug. Connect your positive to the red wire and your ground to the brown wire (also your ground can be securely attached to your frame by a nut located just above your plugs on the frame) and your good to go!.. with the 2010 shift you don't need a battery for it to produce DC voltage.
Nov 04, 2010 | Polaris ATV
Snowmobile
First off, you need to put this under a different product.
For another, check the battery before you ask dumb questions!
Most efi sleds use a battery. Check it.
Feb 01, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
330 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
