Question about Sennheiser RS 120 Consumer Headphones
Green Light not turning on
Transmitter Green ON\OFF light is not turning on
Headphones keep shutting off
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just shut off.
Nov 07, 2014 | Sennheiser Audio Players & Recorders
Why is the green light not on with my senheiser tr120 senheiser head phones
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting.
Sep 28, 2014 | Sennheiser Audio Players & Recorders
Work fine for about 5 minutes than change to static
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just cut out to static.
Jun 25, 2014 | Sennheiser RS 120 Consumer Headphones
Green light is not turning on.. new batteries.. Green light still not turning on
Sorry don't have problem but have the same.
Switch won't turn on the unit. Batteries new.
Sep 06, 2011 | Shure PGX-2 Wireless Handheld Microphone...
When I plug in the power supply to the transmitter the green light goes on only for a split second and goes out. If I wiggle it back and forth and it and out I can't get it to ever find a spot where it...
the sound source MUST be hooked up and running INCOMING SOUND to trgger the transmitter to work.the green light DOES NOT STAY on simply powering up the transmitter......
Jan 15, 2011 | RCA WSP150 Main / Stereo Speaker
How do i program my car to open the door? i have built into my new car. everytime i try to program it, it will not work. what am i doing wrong?
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
If this doesn't work your car and homelink may not be compatible.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Homelink wireless remote is stuck on fast flashing red light. I can't seem to clear my remote to program any of the buttons to my garage door opener. This is the second one I purchased, I had no...
Try this.
HOMELINK PROGRAMMING
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Dec 21, 2008 | Bose Lifestyle 18 System
Sennheiser RS 120 Consumer Headphones Logo
200 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
