Question about Frigidaire Washing Machines
Beep I choose a setting and it will start then make a beep and then it won't do anything. Can u hel me fix this? :(
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Amanda, thank you for allowing me to assist you!
I see that your Frigidaire washer is beeping and will not start a cycle. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. If resetting the power does not correct the issue, your washer could be experiencing a communication error with the control board or could have a wiring failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best of luck - Z
Posted on Apr 03, 2014
Macbook pro won't turn on
have you tried using a restore point? or resetting it to factory settings, although I wouldn't do that until you are left with no other options....You can try to call the company and see if they can walk you thru fixing it.
Oct 16, 2012 | Apple MacBook Pro 13
My computer won't boot from the new disk warrior
Usually three beeps indicate a problem with the RAM, reseat the RAM and then try to boot up with disk warrior. Hope this hels.
Mar 27, 2012 | Computers & Internet
Error code on ps3......will load regular dvds but not games or blu-rays.....code 80010514 pops up
that error is caused by a bad section on your hard drive or a bad installation of firmware, the first problem also causes the later so its usually both. you can fix this problem by formating the hard drive and reinstalling the firmware, but you will lose all your data and saves this way unless you back them up. you can however fix this another way, by accessing the play station's recovery console.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the Playstation System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the Playstation.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the Playstiation System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
if you chose restore file system just follow the prompts and your blue ray drive should work again.
Jun 12, 2011 | Video Game Consoles & Games
MY PS3 WON'T LOAD ANY DISC! This just happened today, and all of my games are in good condition. I recently got the newest update of the PS3 firmware. All I get is a never ending loading circle of doom. D:...
no worries bud...gotchya covered...first off..if u cant access the ps3 main menu at all then u cant delete the update singularily..if u could access the main menu, just go to the item u updated...(i.e playstation home) and delete it and download and reinstall again...if not...then heres the fix...dont worry it wont erase anything, just corrupted data...which it sounds like u have...k....1. Start with having the system in standby (redlight is on)
1. Restart System: Restarts the PLAYSTATION®3 System.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
6. System Update: Update the PLAYSTATION®3 System
I REPEAT CHOOSE RESTORE FILE SYSTEM hope it helps ya!
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
It says error occurred during the start operation(80010514)...anything I can do at all?
The current version of the ps3 firmware has a “recovery console”.
You access it by
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Mar 23, 2009 | Sony Playstation 3 (PS3) Console
I do have a hp notebook and evwery time i try to start the laptop the screen is black and it sounds two times and ....nothing i won,t start what shoud i do??
Usually the beeping indicates that there is some sort of hardware failure. Most popular items in this case is RAM or the video card , but as siawolf stated , we are going to need more information to hel you further...such as the model, and if you have changed any hardware latley....thanks!
Oct 07, 2008 | HP Computers & Internet
I could not access BIOS or anything else on my computer.
Starting the PC without memory will result in a ?beep code? error, which is the beeping you are hearing. Replacing the memory should make the beeping go away. As far as accessing your BIOS if you PC won?t display anything they accessing your system BIOS won?t accomplish anything. -When you start your PC with the memory installed do you see anything displayed on the screen? -Was the PC operating correctly before your reinstall? -Why did you void the CMOS? -Why did you remove the PC memory?
Jul 23, 2007 | FIC P4M-915PD1 Motherboard
Washing Machines Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
