Question about Toshiba Computers & Internet
Toshiba w350t only external monitor works
My toshiba touchscreen stopped working
first get a functioning monitor with a usb connection plug it into your toshiba if that external monitor comes on, access your contol panel monitor setup and see if what the setting is -internal/external monitor if the setting is ok( one monitor relates to the built in monitor / two monitor relates to external monitor) go into safe mode and see if that helps in addition (if n/g with the external monitor the problem could be a missing/corrupt driver/and or virus lastly sys bd=buy another laptop)with external monitor on and you tried everything and built in monitor doesn't function = choice= repair built in monitor or buy another lap top.let me know how things go?
Aug 27, 2014 | Toshiba Computers & Internet
Toshiba satellite c675 monitor light up but not displaying anything
Hook up an external monitor to determine if you have a logic board or LCD problem If the external monitor works the trouble is with the display or its cables. You should also double check that your memory is properly installed and you may want to replace your bios battery. you will need to aquire a toshiba manual for your laptop to help you fix these issues. here is the link for finding your manual Search
Aug 13, 2014 | Toshiba Satellite C675d-s7310 Amd E-480...
I would like to boot a toshiba satellite m105-s30401 with an external monitor as the laptop screen is busted and i would like to use an external monitor until i get a replacement screen, how do i get
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2013 | Toshiba Satellite M105-S3041Notebook
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Dec 07, 2012 | Toshiba Computers & Internet
I need to install external monitor on my toshiba. help
You can switch to anexternal monitor by two methods. 1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the external monitor. 2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key.
Toshiba = Fn + F5
Aug 10, 2011 | Toshiba Satellite M55-S325 Notebook
Hello, I am trying to trouble shoot a Toshiba Satellite a70-s256 laptop. When powered up, the lights go on but there is nothing on the screen. I am attempting to use an external monitor to further...
Hi Barb,
On the Toshiba A70 you should try holding down the fn key at lower left and pressing the F5 key which is the video transfer keyboard command for pretty much every Toshiba laptop. Otherwise, their little pictograms on the F keys almost always have a tiny representation of a laptop next to a monitor.
Hope this is helpful.
Sep 09, 2010 | Toshiba Satellite A70 Notebook
External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Jan 08, 2009 | Toshiba Advanced Port Replicator III...
When I turn on the Toshiba Satellite A215-S7447 laptop, the monitor part of it doesn't turn on with the rest of the system.
Plug in an external monitor. use the <FN><F5> keys to toggle between the internal lcd and the external monitor. If the display external works and the lcd doesn't, most likely a bad inverter board.
My toshiba m105 it wasn't the inverter, it was the lcd itself, the TAB welds were no good but the lcd still worked it just had a 3" vertical blacked out area on the lcd.
Jun 11, 2008 | Toshiba Computers & Internet
Toshiba laptop screen extention to external monitor
you should try and get your f5 key worked, that is where the problem lies.
Jun 04, 2008 | Toshiba Satellite 3005-S303 Notebook
Computers & Internet Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
