Question about Proform ZT5 Treadmill
Backlight display backlight on display went out
My HP Monitor not displaying home computer
It could be your port to your computer that went bad. If you have a graphics card for you computer that could have gone bad. It also could be the monitor port. If the port went bad on either side it will usually say something on the screen about it not having a connection to the port.
It also could be the backlight for the monitor . Sometimes you can tell if the backlight went bad if you turn on the computer and shine a flashlight at the screen. If you see an image then the backlight is bad.
Feb 05, 2014 | HP L1710 LCD Monitor
Backlight on display went dim
If the backlight has failed or a cable is loose you can replace or repair the backlight of the monitor.
replacement parts are available at
www.pchub.com
www.acerparts.com
I suppose the keycombination FN and arrow up or down has no effect?
Aug 03, 2008 | Acer Aspire 5315 Notebook
Backlight not working...........when I first boot up the pc the display will flas on for a second
Hello.
Test with an external monitor and if it works, works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Sep 30, 2011 | Computers & Internet
Instrument panel in 2001 Ford F150 went out. How
If you are talking about the odometer display does not show numbers, here is a detailed instructions on where to find the cold solder joints at :
http://www.f150online.com/forums/electrical-systems/373597-intermittent-odometer-repair.html
This is if the cluster lighting still works, but the display is blank. Don't know if you mean the gauges in the cluster do not work.
Jul 13, 2010 | 2001 Ford F150 Styleside SuperCrew
Communications RCI-6900F-25 CB Radio: the backlight on the lcd display went off...
Wish I had an easy fix for this and a cheap one but I don't the whole LCD will have to be replaced and its not easy or cheap.
May 07, 2010 | Ranger Communications RCI-6900F-25 CB...
Screen went black
For laptops, there is a lighting source behind, called the backlight.
It may happen that only the backlight needs to be replaced.
You can figure this out by looking thoroughly via the LCD screen. As if only the backlight needs replacement, you will still be having display behind.
Otherwise you will need to replace the unit.
Mar 15, 2010 | Computers & Internet
Is there a way to turn off the keyboard lights. It is nearly impossible to see the letters when the lights are on.
I went to Settings/Display/Backlight Timer/Display & Keypad then selected off.
You can see the keys on the keypad a lot better with the backlight off.
Nov 19, 2009 | LG Neon GT365 Cell Phone
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
Motorola razr phone
It sounds like the backlight in he LCD display has gone bad in the phone. Most displays now have an integrated backlight, so the entire display will need to be replaced. Its not considered to be a user replaceable component. Unfortunately, you'll have to take it to be repaired. The fact that you said it was "fading" before it completely went black tells me that it was going bad and about to fail.
- Jim
Feb 12, 2008 | Motorola Mobility RAZR V3
Display backlight problem
i have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Sep 21, 2007 | LG VX8300 Cellular Phone
Proform ZT5 Treadmill Logo
48 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
