Question about Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power
Won't turn on has no power bad fuse?
Turned off while plugged in
    Problem Solver:
  • 33 Answers
Try wiggling cord to see where the open is.
Posted on Aug 14, 2015
I've just moved house re plugged in my base station and now no power to it? Was working fine. Tried in a few power sockets still won't switch on. Will check fuse.
Maybe the outside fuse box has been turned off, or the house just has a lot of bad sockets that have to be replaced.
First check the if the outside box is on, switch in up position.
Then walk around with a small lamp and try it in all wall outlets to determine which are good or bad sockets.
Then replace all the bad ones. With the power turned off again for safety.
May 05, 2015 | Lands Phones
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My car won start and I already replaced the spark plugs
power pack to spark plug wires is bad are poor conection.allso check make sure car is getting gas if no sound of fuil pump kicking on when ignition is first turned check all fuses if good replace fuil filter.
Jan 19, 2013 | 1992 Buick LeSabre
I replaced the ignition lock cylinder in my 92 cabriolet and I turned the key and it started first swing, then I was putting the steering wheel covers back on and it just turned off... When I try to turn...
If it's an automatic check fuse #15 wether it's a stick or automatic you should have power at the red & black wire coming out of your ignition switch when you turn key to start postion and power at the red wire going into switch at all times. if no power coming oit on the red/black wire you need an ignition switch. if there is power coming out of switch try putting car in nuetral (for auto trans). if still nothing you'll need to check for power at small wire going to starter when key is turned to start. if has power then need starter if no power you'll need to check starter interlock relay.
Dec 31, 2012 | Cars & Trucks
The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
Dec 08, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
My 94 s10 blazer won't start. Turns over hard. Pulled plugs, turns over easy. ECM fuse replaced-was bad. Fuel pump good,spider gets gas on plugs,distributor was loose,good spark on plugs.Plugs back in-...
what happened the last time it ran
did it run hot or ??
Check the oil - if none -- you could have turned a bearing. In that case, the next would be a compression test.
Best regards
Ck
Aug 18, 2011 | 1994 Chevrolet S-10 Blazer
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power Logo
54 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
