Question about Frigidaire Washing Machines
Frigidaire Gallery GLTF1670AS0 washer leaking
Recently my front-load washer GLTF1670AS0 started leaking a small amount of water on the back left side. Removed front panel but no water source visible. Oherwise washer works well for 11 yrs old.
  • jetfixr Mar 31, 2014
    Hi Ann Setap, Not sure of your exact model but I believe the water supply lines connect in that area. You need to look at the back and see if the supply hose connections are leaking. After that I would remove the top and check the water valves. You can see much better with the top cover off. Let us know.
  • 883 Answers
SOURCE: Frigidaire gltf1670as0 Front Loading Washer
door lock position switch may not have been properly tightened at factory. first position then tighten the switch
Posted on May 23, 2007
BADBOYJAY
  • 264 Answers
SOURCE: Frigidaire Front Loading Washer Leaking
there should be a rubber pipe going to the soap draw to the drum normally there's to pips one at the front of the machine and one on the top it is there have a good look in the machine make sure its un plugged be for putting your hands in the machine ok
Posted on Jan 05, 2008
  • 351 Answers
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Posted on Mar 21, 2008
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Posted on Jun 15, 2008
Frigidaire gltf1670as0 uses to much water. Washing machine pulls water in and then pushes it right back out. All cycles are working but our water bill doubles each month we use it.
I would double check the drain hose, it sounds as if you are siphoning as it fills. The drain hose must be higher then the washer itself to prevent this from happening. If this does not solve this issue, get back to me and we can would on another possible solution.
Thanks, Gere
Oct 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Clothes left with grease smears
There are two real possibilities, both are in the washer. The first is
that the gear box seal is failing, and the second is that the fabric
softener dispenser needs to be dismantled and cleaned out.
"When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail. As I recall, the seal wasn't difficult to replace,
but to get access to it I basically had to disassemble the whole
machine. The hardest part was pulling the agitator off the shaft - I
used a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way
Apr 15, 2008 | Frigidaire GLTR1670A Front Load Washer
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
Tromm Washing Machine small leak
Front load washers will always have some water in them. if, it leaking out, you may either have a bad seal, these are double drums, you may have a leak at the discharge house coupling at washer
Jul 02, 2009 | Washing Machines
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Banging and small leaking
Is this a front loader you have? the banging could be broken shocks.
Mar 11, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
