Question about Garmin Alpha High-Performance Dog Tracking and Training System
My garmin alpha will not turn on
Won't turn on
Fuse replacement
The fuse is integrated in hte AC socket. You'll need a small screw driver to pry up the part that talks about the power requirements. Check the online manuals for more details.
Aug 24, 2013 | PSB Alpha Sub Zero Subwoofer
Garmin won't switch off
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults. ..reassemble
Feb 06, 2013 | Garmin Edge 705 Handheld GPS Receiver
My garmin nuvi 1300 won't turn on
The Garmin Nuvi gps probably has halted to to either a software or hardware flaw. Sadly about the only way to bring it back may be to reset it to the factory defaults. Depending on your model, this might lose all your saved data.
Aug 24, 2012 | Garmin Nuvi 1300 GPS Receiver
My Garmin nuvi 295W won't turn on at all.?
Did you get the battery reinstalled correctly? The battery and a question mark means there's a battery problem.
Garmin Nuvi Gps
Aug 19, 2012 | Garmin Nuvi 295W 3.5 in. Car GPS Receiver
Receipt won't print on royal alpha 1000ml
Make sure you use thermal paper and no other kind.
May 12, 2012 | Royal 29043x Alpha 1000 Ml Cash Register
Why won't my car start without getting a jump? Once I get it jumped it runs really good but when I turn it off and try to start it again, it won't start. I have a new battery and a new alternator...
Buy yourself a volt meter and check the batter voltage before and after it starts. You should read 12 volts before starting and around 14 volts once it starts and the alternator is charging the battery. Also check for loose connections between the alternator and battery. Check that the ground wire from the battery is secured to the vehicles frame. Good luck!
Oct 18, 2011 | 1987 Audi 5000 CS
The letter 'r' is no longer on my alpha address screen
I can help you fix your Garmin Nuvi 200W.
The Nuvi's brain has had a stroke; you can give it a new brain again with a system software update.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 31, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Alpha High-Performance Dog Tracking and Training System Logo
105 people viewed this question
Top Garmin Home Security Experts
Lawrence Oravetz
Are you a Garmin Home Security Expert? Answer questions, earn points and help others
