Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
My 250q surges speed control doesnt work
Fein mult
  • Fein Master
  • 1,793 Answers
Fein 30762198013 but first before replace try to clean the variable resistor with a contact cleaner or wd40. and blow it out of dirt little chance sometimes it can help.
Posted on Jan 01, 2016
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Need switch for Fein mdl 9355.13 vac. Where to purchase?
Type www.fein.com in the address line in browser. It should take you to Fein in your country. On the left hand side of screen you will see a list of links click on service then Authorized workshops that will give you a list of places to fine spare parts and repairers.
Mar 26, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
Multimaster stopped working
First control the brushes for the length or a spontaneous broken cable . or elecric modul has MEASURE is neccesary of the 4 electric field contacts also.
Dec 22, 2011 | Fein Multimaster Rs - Msxe 636 - 2 Rs
FEIN 9.55.13 WILL NOT TURN ON. SWITCH? BRUSHES?
replacement parts for that model can be found at amazon, click here and take a look: Amazon com fein vacuum parts . Have a nice day
Sep 12, 2011 | Fein 9-55-13 Turbo II Bagged Canister...
Fein 9-11-55 - it does not start. worked great for years, but now it's dead,
These high speed motors have carbon brushes which wear out with use, or sometimes just get stuck because of moisture, dirt and corrosion and don't make a proper contact.
Assuming the wiring and the switch are not at fault, a temporary cure might be to to just hit the motor casing with something that will not damage this casing.
I'm serious! This shock usually will dislodge the spring loaded brush(es) and get it released enough to make contact with the collector.
As I said, this is only a temporary measure, for if the brushes are so badly worn out the collector can be damaged, and then you're looking at replacing the whole motor.
If you value this vacuum and it hasn't been serviced for a long time, your best bet may be to spend a few dollars and have it serviced properly.
It will serve you well for a long time.
Feb 15, 2011 | Fein 9-11-55 Canister Wet/Dry Vacuum
Where can I purchase a switch for the MSxe 636 II Fein Multimaster?
http://www.ereplacementparts.com is one of the online shops in you Country or a dealer for FEIN in your immediate environment.
Jul 29, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Cracked lid/top of fein vac model 9-55-13
Contact Rudi at E & H Repair in Chicago. They are an Authorized Warranty Repair Center for Fein. The phone no. is 312-829-6770. Email is rudi@kooltools.com. Good luck
Jan 20, 2009 | Fein 9-55-13 Turbo II Bagged Canister...
RPM will start to slow and then almost quit
fein i believe is made in europe. i am guessing its the hz problem co`s the electronic to failed
Feb 22, 2008 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
74 people viewed this question
Top Fein Vacuums Experts
JoeVacs
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
