Question about Bikemaster Trugel Battery MG7B-4 YFZ450 DRZ400 KLX400 DS450 TTR250
Trugel battery wont take charge
Went dead over the winter - wont take a charge
Speed problem
check the alternator. if the engine is running fine no problems but stuck only doing slow speeds would check the charging. if this is fine check the spark coil.
Mar 11, 2014 | 2004-2006 Kawasaki Kvf700a B Prairie 4x4...
Battery went on dead on my c3 yahama one night charged battery now turns over good but wont crank please help ! thanks
battery may be dead-it might charge up but wont hold enough power to turn bike over -buy new one
Oct 29, 2013 | 2007 Yamaha XT 660 R
My chair sat all winter. the batteries went dead so i replaced them. now when I turn it on it will not go out of 1st. 1st is fine, but very slow. when i push up the lever it blinks, but I can't ge
I assume you have deep cycle Gel or AGM batteries. Looks like you did not break in your batteries properly. It takes 5-6 full charges to get them up to 100%. Many experts say that you should never unplug your power chair and to always store it disconnected with a full charge, in a warm place.
Apr 30, 2013 | Health & Beauty
Battery went dead
boost your battery.put it in sellphone.then charge your phone?
Feb 28, 2013 | LG Lucid VS840 4G Verizon
I left the ignition on and the battery went dead. now the battery wont hold a charge. i can charge overnight starts right away. ride for 30 mins. turn off and it wont restart.
Is this an acid batter? If so you may need to add water to the appropriate levels for it to hold a charge after you put it on a trickle charger. Otherwise, I would say the battery is dead and you need to replace. Good luck!
Jul 30, 2011 | Yamaha XS 400 SE Motorcycles
Battery Problem
yes it is possible that its bad and you can tell by after you charge it with the tender, take a voltage reading, it should be about 12.6v-12.8v on a fresh charge, if it just shows 12.0v that's not enough and one of the cells might have went bad.
May 03, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
I have a 2001 BMW Z3. The battery went dead last
most new BMW's the fuse block is located behind the glove box. There should be a pair of twist plastic fastners at the back of the glove box, twist and remove the plate and you should find the fuse box and fuse locater list.
May 12, 2009 | 2001 BMW Z3
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Bikemaster Trugel Battery MG7B-4 YFZ450 DRZ400 KLX400 DS450 TTR250 Logo
27 people viewed this question
Top Bikemaster Electronics - Others Experts
Are you a Bikemaster Electronics - Other Expert? Answer questions, earn points and help others
