Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Chainsprocet worn sprocet
  • Husqvarna Master
  • 1,807 Answers
How do you replace sheared bolt on clutch sprocet
Either extract the broken piece with an easy-out or drill and tap a new hole. Or go buy a new refurbished chainsaw and donate that one to a small engine shop.
Feb 15, 2016 | Cars & Trucks
Repair manual to replase the timing chain
Line up all the dots on the cogs with the covers put engine on T.D.C. and every thing should line up , dab marks with white out to high light the marks.
Nov 08, 2014 | Cars & Trucks
Pedal slips while riding
loose sprocet on rear axel shaft skips every so often
or slips
Feb 26, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
FRONT DERAILER WON'T CHNGE ALL 3 SPROCETS, I HAVE TRIED ADJUSTMENTS SCREWS
change the shifter to the smallest gear, pedal while you shift. Once you get it there check the tightness of the cable that is going to it. If it is loose get a 9 mm combination wrench, loosen the clamp located on the front derailleur at the end of the cable. Pull the cable through the clamp and make the cable tight then tighten down the clamp with your wrench. This should make it go up to the biggest gear now. If it doesn't play with the screws, they are travel limiters.
Aug 13, 2013 | Mongoose Cycling
Bycicle chain derailer
Hi jeanburkhart...
Go to the following webpage and view the sprocket and chin connection
Please rate me
Bud
http://www.youtube.com/watch?v=2j1gSwhsVN8
Sep 25, 2012 | Cycling
Finding the rigth sprocet seting
The 'right' sprocket is subjective. Gears allow you to match your desired effort to the conditions.
Use a search engine "how to shift a bcycle".
Jul 16, 2011 | Cycling
Since I bought my new FZ 1N in 2009 i'm in trouble with the first gear in cold and over 80 degrees warm conditions. By taking first gear you can hear and feel a terrible loud bang. If you have any...
There could be many issues that make this noise.. but the temp range is an indicator.
There is an drive shaft in the center of the clutch.. at the outside end of this shaft there is a "core plug" or "clutch shaft plug" this plug ensures oil does not come out the end of the shaft and instead is directed to the clutch plates.
It is a small 1/2 button looking thing and it is not unusual to find it laying the bottom of the case or cover housing when one removes the cover. It just vibrates and wiggles it's way out over time. If this is the case.. remove the cover.. find the plug..use some locktite when reinstalling it.
The other causes are;
Worn chain.. they don't wear evenly and slack can be found in different places.
(Always replace all three; Chain, Rear and Front Sprocet as a set)
Dry or out of adjustment chain.. too much slack
Loose bent or worn shift fork
Broken Clutch Basket
Broken Clutch plate
Worn or bent shaft
Worn or broken sprocket
etc etc
I doubt your clutch cable free play could be so whacked out to cause that type of noise.. however..it would be a good idea to check just to eliminate it.
Regardless.. it's more than likely gonna have to be taken apart and inspected.
Best of luck!
May 12, 2011 | Yamaha Florett RMCG 125 Race Motorcycles
Homelite chaine model # av27 need sprocet belive part # upo6967
Your saw is probably a 27AV. They can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Type "27AV" in the "Model Name/Number:" window, click Search.
10 different models appear match the UT-108?? number on your saw.
I chose one of them, chose item 26 (pn UP06967) on the "Clutch-Chain Brake-Drive Case Cover" detail, clicked "Add to cart" they are $15.60 (new pn 000998263 it now includes a bearing). HTH
Lou
Sep 28, 2009 | Homelite Garden
1999 Honda Civic DX no top acceleration.
timing will out use a ruler to align the the 4 marks on the sprocets if its a dohc, be sure its on T.D.C
Nov 16, 2008 | 1999 Honda Civic
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
42 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
