Question about Homelite Garden
Just plain gas or a mix in my Homelite 25cc zip start gas trimmer
Dear tech support person,
I figured out how to put in new string and how to start it up. I did one area of the yard.
I'm trying to surprise my husband with the trimming done and it ran out of fuel. Do I just put gas in it or use some sort of mixture of oil and gas?
I can't find it in your list below. But it is a 25cc gas Homelite Trim n Edge Zip Start. The number I found on the machine was UT20779.
I'd appreciate good help. I don't want to mess the machine up putting the wrong stuff in, but, I want to get this done.
Thx so much! JT
  • 284 Answers
You will have to mix oil and gas in a one gallon container
your ratio will be 40:1 that is 3.2oz of oil to one gallon of gas
you will need two cycle oil as some are pre bottled at this amount and some you have to measure as some dispensers have markings for you.
Do NOT USE MOTOR OIL OR OUTBOARD MOTOR OIL.
I would use 89 octane mid grade especially if fuel will be sitting.
Look for the 2 cycle oil that contains a fuel stabilizer in it if possible if not thats fine.
Dont want to throw you off but some will say you can use a 50:1 mix---2.6 oz to 1gallon
if you can find the SYNTHETIC type 2 cycle oil this would be your alternative and would be ok to use also.
Posted on Jun 15, 2009
Need oil mix ratio for 25cc homelite gas trimmer
Hi anon the mix ratio is 50:1. That's five litres of unleaded and 100 ml of 2 stroke oil
Sep 10, 2014 | Craftsman 25cc Gas Line Trimmer
I have recently obtained a Homelite "zip start" trim n edge string trimmer. What fuel mixture is recommended for it?
Modern Homelite equipment uses a 50;1 fuel mixture. That is 2.6 ounces of 2 cycle mix to 1 gallon (U.S.) of gasoline. I highly recommend to use a quality 2 cycle oil that is designed for lawn equipment. I also recommend to use a mix that contains fuel stabilizer. This will usually be in a 3.2 ounce bottle.
Always use fresh fuel, it prevents problems in your equipment.
Nov 29, 2010 | Homelite Consumer Products MightyLite...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Was given a homelite zipstart versatool string trimmer (25cc). what is the proper gas to oil ratio for this tool?
between 32:1 and 50:1 should be OK.
The best bet is to buy the premeasured 2 cycle fuel/oil mix in the bottles. They come with 8oz for a gallon of fuel.
Sep 23, 2009 | Garden
25cc trimmer gas ratio mixture
the correct ratio is 50-1 mix
Jul 01, 2009 | Homelite Garden
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite string trimmer - gas
put it in the trash and buy yourself a new one nto the same brand.
Aug 09, 2008 | Electrical Supplies
Garden Logo
1,423 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
