Question about Trekker Hiking Staff
Over extended will not go back together
Can't get shaft back into top shaft
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 168 Answers
Sounds like you need to pull the plastic cover down (were the pole is trying to go in) you should see a push button press this down and push back in, then once it is back in and clicked in place push the plastic cover back up.
job done
Posted on Sep 24, 2014
Replace spindle shaft on 42 insch cutting deck
take the deck off. the shaft you want to replace take the nut off the pulley on top and hit it with a hammer it should fall out the bottom. take blade off and there go. be sure bearings are good put new shaft in and put pulley and washer and nut and blade . take a picture of how it comes apart so you don't forget when you go to put it back together.
Jun 29, 2016 | Garden
Extended cab. How do I uncross gears?
if you are stuck in gear it is not a basic rebuild but a bad rebuild
because of the design of the gear selection process , it is impossible to have 2 gears selected together as one selector shaft will not move unless another selector shaft is in the correct position ( neutral ) to allow the detente balls to move out of the way so the next selector shaft can move
it is possible that the gear stick is not in the correct position when it was installed back onto the top of the box and one gear was selected and the end of the lever came out of the selector slot or all the selectors were not in the neutral position and so the end of the lever went behind a selector rail
pull the gear lever turret of the top of the box, move the selector rails until they all line up as a slot across all of them , then put the gear lever end back in that neutral slot
Dec 27, 2015 | 1992 Ford Ranger
I have a 95 grand Cherokee orvis I I blew the front cvjoint drive shaft apart how does the top head go together ? Bearings the slotted crown . How does it stay together I have it apartt along with new...
the part that the bearings run in is possibly that worn it will not hold together. I have repaired CV Joints before and you usually replace the whole knuckle at the end of the shaft or exchange the shaft for a reconditioned one.
Jul 23, 2014 | 1995 Jeep Grand Cherokee
Short drive shaft for j.d. snonw blower
One of the groves in the shaft has a wider slot than the others. Aline these groves and it should go back together.
Feb 01, 2014 | John Deere Garden
How do i adjust the tension on a ActionC100 exercise bike
I just fixed a C100with the same problem today as follows:
Take off the pedals, seat pole, and side panels ( 3 long screws on the top and 4 short screws on the bottom then push out [from the inside] the pedal shaft outlet covers and gently take the covers off by turning the pedal shaft). You'll see the cable to the wheel and secure it to the lower chassis rail by tape or a cable tie, then undo the lock nut on the cable end and extend the screwed sleeve by 10 mm. You'll then see that pulling and releasing the outer cable will loosen and tighten the magnetic brake more smoothly. Good Luck, Andy
Dec 29, 2012 | Exercise & Fitness
Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Dec 18, 2011 | Toys
I HAVE A CHEVY UPLANDER AND THE REAR WIPER WILL NOT WORK IT DOESNT EVEN MOVE
The rear wiper on the uplander is a common BOSCH unit and is very prone to one very small but very easy ( and CHEAP to fix ) problem. The shaft that goes through the glass on the rear hatch needs to have new grease.Thats it......If you think you need a new wiper motor try this.......take off your old wiper motor and remove the star drive screws that hold this thing together.Now pull this thing appart. Dont be afaid to do this remember you think that you are going to buy a new one anyway right. Inside you will see the electric motor with a worm gear thar turns a big yellow(or white) plastic wheel.sitting on top of that is a funky metal linkage that is connected to the BOTTOM of the shaft.On the TOP end of the shaft you will need to remove the small plastic ring and under that the small rubber o-ring. Now you need to pull the shaft and the linkage out of the unit. They should just pull out with no effort BUT you will find that they are stuck because all the grease has gone hard around the shaft stopping it from moving.Use a little penitrating oil around the shaft and work at it and it will come out. Now use a little break cleaner to clean the shaft and linkage ,apply new grease and put the thing back together again. PROBLEM SOLVED......try it .....trust me you dont need a new motor :-) If you really want to be lazy you dont even have to take the car apart just unbolt the rear wiper arm and remove thearm fron the car then clean the end of the shaft andunder all that dirt you will see the small plastic ring and under that the small o-ring .....remove both of these.now spray some penitrating oil down the shaft.give it a little timeand spray some more.try the rear wiper,if your lucky it will start to turn.put it all back together again.
Jan 11, 2010 | 2004 Chevrolet Uplander
Agitator came apart while doing laundry
There is a bolt that holds this together that screws into shaft. Is the upper agitator broke? Or the ratcheting part in the center? Give full model number to further assist you.
Jun 15, 2009 | Kenmore 15864/15862 Top Load Washer
Bolts wont reach
ok first off i am confused are you sure you have a Kenmore top load ?? You said you had to replace the coupling so i will assume the unit is a direct drive....The pump goes on by 2 clips and fitting it into the motor shaft I dont understand what bolts you are talking about>>????
Jan 22, 2008 | Kenmore 24032\24036 Top Load Washer
The power is in but the blade wont move
Your best bet is to UNPLUG the fan, remove the protected cage and the cover that protects the motor and take a can of compressed air and blow out any dust that you happen to see that has built up in the fan. Then look for a bushing that is towards the front of the shaft and the rear of the shaft and place a drop of 3 in 1 oil where the bushings are located. I would place a couple drops on the front and rear shaft, spin the shaft by hand, move it back and forth, then then put it back together again and try it.
This should extend the life of your fan as long as the motor isn't burnt up, and the fan hasn't been left on for a long period of time when the blades where not moving.
Hope this helps.
Keep in mind.. a little maintenance goes a long way.
Dec 04, 2007 | Honeywell HS1750 Stand (Pedestal) Fan
Trekker Hiking Staff Logo
729 people viewed this question
Top Trekker Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Trekker Health and Beauty Expert? Answer questions, earn points and help others
