Question about Promise Smartstor NS2300N 1000 GB Network Storage Server
Promise ns2300n larger hdd
I put 2x 2TB to replace my 2x 500GB hdd, but only 500GB are detected, hwo to recover the missing 1.5TB
What size power supply for the wd50001032001 how many volts ?
It would appear to be 12 VDC for that type of western digital my book external hard drive. Found a oem selling them on Amazon: T-Power AC Adapter for Western Digital APD DA-48m12 My Book Pro Edition 500GB~2TB drives WD50001032-001 WD4000D032 HDD WD1600B014-RNU WDXUL2500BB wd6400h1u WD1200B007 HDD WDG2TP10000N NAS Network HDD
Nov 02, 2017 | Power Computers & Internet
Could a PlayStation HDD Work With a Computer PC?
Simply put, yes. HOWEVER, you need to reformat it. The PS3 and PS4 both us SATA 2.5" HDD. So, essentially, you can use that drive in your laptop, but you'll need to reformat it first.
And just as easily, you can always swap out the 20, 40, 60, 80 GB, etc HDD from the PS3 (or the 500GB and 1TB HDD from the PS4), and put in a larger SATA 2.5" HDD to replace it. All you have to do is format it appropriately for the PS3 (or PS4).
Jun 06, 2016 | Video Game Consoles & Games
Can I upgrade the PS4 Harddrive?
The PS4 will allow you to use an external drive to store data other than games. If you put a game on an external drive, it wont work. The drive in the unit is 500Gb
Jun 28, 2015 | Sony PlayStation Video Game Consoles &...
What is maximum GB supported for hard drive
Normally there is not such limit in recent moterboards, but if you used old motherboards which released during 2007-08 they can support upto 500GB per slot, and there is normally 2-4 slots for connection of HDD.
In this way you can have upto 2TB of HDD storage.
Apr 06, 2014 | AOpen vKM400Am-S Motherboard
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
Want to install my 2tb hp external hdd not recognized lights up beeps when connected but nothing...have a 1tb hp that is fill to the brim tha twas assigned drive j:...but when trying to connect this new...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files. you can find it from facebook
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | HEWLETT-PACKARD 2TB 3G SATA 72K 35in MDL...
What Is The Bigger Hard Drive I Can Use
It looks like this computer only supports IDE hard drives.
The larget drives are all SATA hard drives. You can get a host card like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16816102065 which will give you some SATA ports. Make sure you have a free PCI slot.
There's a limitation with current operating systems that won't let you have a boot drive be larger than 2.2TB. I wouldn't recommend getting a drive larger than 2TB for that reason.
Good luck.
Mar 01, 2011 | Dell Dimension 2300 PC Desktop
Hello, hard drive is not visible in the physical drive list. I was using my External HDD for almost 2months (500GB Western Digital). Suddenly the Drive missing. So followed my friends guide to get...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Sep 16, 2010 | Western Digital 320GB MyBook External USB...
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Promise Smartstor NS2300N 1000 GB Network Storage Server Logo
78 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
none
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
