Question about Stihl Garden
How do stihl combi attach is it a push in
Is it a push in fit
Tore the saw down two wheeks ago got the parts for four the saw four got where the whires go on coil. And the switch stihl 021
I believe you have 2 wires apart from the ignition wire to the spark plug. The black one goes to the on/off switch and the yellow / green goes to earth and is normally attached to a screw near the ignition module - one that fits into the metal body or the engine lump.
Dec 24, 2016 | Stihl Garden
How to replace worn rubber isolation grommet on stihl 026 chainsaw
I assume you mean one of the anti-vibration rubbers. Look inside it to see if it has a T27 star shaped screw head. If it has undo the screw. If not then it is the push fit type that literally pushes in and out of the hole.
Nov 03, 2016 | Stihl Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Stihl hl95, 100
Is the 'cutting head' in a work position and not folded back.? Does the drive shaft spin.? Is the attachment on the shaft properly.?
May 02, 2014 | Stihl Garden
Stihl hl95 100 hedge trimmer
Does the driveshaft spin.? Is the 'cutting' attachment in a work position? Is the attachment on properly?
Will a complete engine from a stihl 017 fit into a stihl ms180 chainsaw.
you should be able to get the engine to fit. The 017, ms170 and ms180 are all part of the same family.
Jan 15, 2013 | Stihl Garden
Fitting line to stihl fs 38
If its the auto feed style head, you need to push the two tabs in on the black feed head, the outer ring should then just pull off, exposing the bumper feed cap/spool.
Jun 25, 2012 | Stihl Garden
Black arms in clutch dont allways come out and catch when rope pulled. Chainsaw rope pulls out without catching and turning over to start. What should i do?
Most Stihl starters that i have seen rely on the r clip securing the pulley on being a tight fit on the shaft, this creates a friction, as the pulley turns the clip trys to stay still and in turn pushes the pawls out, remove the clip and squash it close together to create a better fit on the shaft
Jul 09, 2011 | Stihl Chainsaw 045 056 Clutch Chain Saw...
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
