Question about Rival VS230 Seal A Meal Vacuum Food Sealer
Not sealing the bag
Not bseal
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
My husband is a fisherman here in Key West and swears by his vacuum sealer, but he was about to throw it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem and may help some, but not all of you.
Apparently, it was all about bag placement for us.
When you're just trying to seal one end of the plastic to make a bag from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Posted on Feb 03, 2015
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 | Vacuums
When I use my Powerglide Pet bagged vacuum cleaner, the debris does not go into the bag but on top of it. What should I do?
Usually there is a "seal" to make sure the dirt goes into the filter.
I guess the air flow is bypassing the seal somehow. Is the seal clean, is it in good condition?
Are you sure you have the right bag?
Mar 09, 2015 | Top Vacuums
I own a department store. I want to buy some cheap but strong plastic wrap seal. I have had many cases of customers adding stuff to the bag in the store after paying bills. So I want to seal the bag a
I think you should buy plastic bodied 1mm in diameter cable for your store. I have seen many department stores use these kinds of plastic seal in the bag so that people cannot add more stuff to the bag after buying the stuff. http://www.tydenbrooks.com/Products/Indicative-Seals.aspx provides wide range of seals. Check which one is fit for your store bag. I highly recommend cheap plastic ones for temporary use.
Jan 13, 2014 | Book Cases Galore Martin Tribeca Loft Wood...
Philips food sealer kb1000
First you have to make a bag, so pull from the roll to the size you need, you might want to practice with a small one the first time.
Press the lid gently and the heat light should come on, when it turns green open the lid and you will have sealed one edge of the bag. (usually red means it is heating and green means it is finished)
To seal, place the bag over the vacuum nozzle to remove the air, usually pressing one corner starts the vacuum. When as much air is gone as you want, gently press the center of the lid again, and when the light is no longer red your bag should have the air gone and the bag sealed. DO NOT press too strongly on the center as that will cause the heated wire to cut the bag.
Mar 03, 2012 | Kitchen Appliances - Others
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
Feb 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 | Vacuums
I have a canister vacuum. I replaced the bag and now can otn get a good suction. Could it be the rubber seal near the bag?
The case that encloses the bag may not have been closed properly, or a part of the bag got caught in the seal of the case. Take the bag out and reinstall. Hope this helps!
Mar 12, 2010 | Vacuums
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
How to operate a Salton vacuum bag sealer?
HOW TO MAKE A BAG
1. Place the BAG SEALER on a firm level surface adjacent to a power supply socket. We suggest the bag sealer be positioned away from the edge of the work surface allowing plenty of clear space for making the bags.
2. Take the polythene roll and insert it in the trough in the sealer, positioning it so that the film is pulled of the roll from the underneath.
3.Polythene roll supplied by Salton (Cat No. 1121) is a high grade film suitablefor use in a microwave oven, boil-in-the-bag cooking and for storing in the freezer. Replacement rolls are obtainable from stockists, or in the case of difficulty, from Pifco Servive Department.
4. Plug in to mains supply socket and switch on.
5. To make the first seal on a new roll of polythene, lift up the cover and pull out enough film to project an inch (2.5 - 3 cm) or so outside the casing.
6.Now press the lid down firmly so that both the red and green indicator lights come on. In a short time - approximately 6 seconds - the green seal light will go out. AS soon as this happens lift the lid and peel of the film.DO NOT ATTEMPT TO PEEL THE FILM AWAY BEFORE THE GREEN SEAL LIGHT GOES OUT.
7.NOTE - when closing the lid and applying pressure two distinct clicks will be heard.
theses are the switches which operate the two functions of the BAG SEALER.
First click - Operates the air extraction motor. Vacuum light (RED) ON.
Second click - The sealing wire is energised. Seal (GREEN) and vacuum light (RED) both on.
8. We suggest that you famillarise yourself with the pressure mechanism before you begin using your BAG SEALER. It is perfectly safe to operate either the seal or vacuum functions with out using any polythene roll.
9. After several uses deposits of polythene on the sealing wire can reduce the effectiveness of the seal. Theses deposits of polythene can be removed by operating the seal mechanism without any polythene across the wire.
10. Having sealed one side of the bag, pull out the film to the desired bag width (MAXIMUM WIDTH is 2.9 cm / 11 1/4 inches) and seal again by closing the lid and pressing down hard.
11. As soon as the Green seal light goes out, lift the lid and peel the bag away. Ensure no film adheres to the sealing wire.
12. This seal creates your first bag and at the same time the first seal for the next bag.
SEALING A FILLED BAG (WITHOUT AIR EXTRACTION)
1.Make sure that no food or liquid remains in the top portion of the bag close to where the seal will be made as this may effect the effectiveness of the seal.
2. Place the open end of the of the bag over the sealing wire making sure that the film is flat WITH NO FOLDS OR CREASES ALONG THE LINE OF THE SEAL.
3.Close the lid and press down firmly to make the seal.
EXTRACTING AIR FROM A FILLED BAG.
REMEMBER: Do not extract air from bags containing liquid !!!
1. After filling the bag and making sure that the sealing area is free from food particles, place the open end of the bag over the sealing wire and place the black air extraction nozzle well inside the bag. It is important to ensure the the two edges of the bag under and over the nozzle are straight and not creased in any way to ensure an air tight seal !
2.Depress the lid gently until the red light comes on and hold this position to operate the air extractor. (DO NOT press so hard as to activate the the green light and therefore the sealing wire).
3. As the air is being extracted it is sometimes of help to hold the bag with your hand and gently move the contents around to help channels of air to form, so aiding extraction. Depending on the the nature of the porosity of the food some unavoidable air pockets may form but moving the contents around these can be minimised.
4.Once all the air has been extracted increase the pressure on the lid until the green light comes on. This must be done in one continuous movement, otherwise the air might seep back into the bag. Once again the bag should not be pulled away from the bag sealer until the green light goes out. Pressure on the lid should be released, the lid lifted and the bag peeled away.
LAMSBREAD :)
Sep 27, 2009 | Kitchen Appliances - Others
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Rival VS230 Seal A Meal Vacuum Food Sealer Logo
623 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
