Question about Nixvue Digital Album II MP3 Player
Digital Album Lite
Looks like the picture.   lost charger  what is the polarity of the input pin
Tip positive or negative
0 characters
1 Points
My max v8 mp6 player's all software was lost from the dosn't do any functions in it other than max screen .no other functions are possible.but is charging through pc as well as charger. all its...
my max v8 mp6 player's all software was lost from the dosn't do any functions in it other than max screen .no other functions are possible.but is charging through pc as well as charger. all its softwares such as notepad,fm radio,picture viewer,e-book,slide show with music,pocket album,optical zoom, games ,camera ,supports SD/MMC, high speed usb 2.0,movie play back option , viedeo and sound recording all was lost or not working .want an valuable advise osolution from experts.what i want to do
Mar 13, 2011 | GPX TEC100 MP3 Player
I need to locate an owners manual and replacement charges for the BellSouth 1010 2 Way Radios. Our CERT group just had 26 of these 2 way radios donated to use for our training but they came with no manuals...
I have found this manual for the Bellsouth 1010
There is no picture to confirm it describes the correct model, but hopefully it will help.
As to a charger there is one on eBay for an unspecified piece of Bellsouth equipment.
Description: AC ADAPTER CHARGER. BELLSOUTH. Model HB-35US-01. Input 120 VAC, 60 Hz, 5 W. Output 9 VDC, 300 mA. Output connector measures 0.216", center hole measures 0.095". Center hole is negative.
It looks to be available here
9volts DC at 300ma looks to be a suitable voltage and current to charge 4 AAA cells.
If it looks to fit you could purchase one for proof of concept. Try it out one one that is lacking in some way, and see if it charges 4 rechargeable AAA batteries. If it does not look like it plugs in, and the handset needs a cradle to charge, forget it, as I don't even know if you have a budget, and consider plan B.
If they are only to be used for training purposes you could consider running off batteries, changing them when flat. You could go through a huge number of alkalines, so rechargable might be advisable.
I don't know what you can get locally, but I get rechargeable batteries and chargers from China offeBay at ridiculously low cost, pity about the 2 to 3 week postage delay.
It's a rough and grotty solution, but may do for proof of concept.
And who knows? I'm in Australia and like the free postage options, you may be able to do better.
Jan 30, 2011 | MP3 & Digital Media Players
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
No Album Art
Was there a picture within the music album folder? You can manually put it there by opening the album folder and insert a picture of your choice along with the music.
It should recognize the picture and appear when that particular album or song within the album plays
Jun 14, 2009 | Creative Labs Zen Digital Media Player
GoGear SA3345
hey i have the same mp3
its not possible it doesnt work, i have tried everything but it wont work
sorry its NOT possible its just a thing to be honest ....
Oct 31, 2008 | Philips GOGEAR SA6045 MP3 Player
Recharging batt. on emerson mp3 digital media player
if your mp3 player comes with a usb charge cord and has no bulge in the cord, such as would contain some kind of voltage modification electronics, then it's ok.
   the reason is: both the motorola charger and the usb port are  5 volts, all usb is 5 volts standard, and the motorola charger is labeled 5 volts right on the unit itself.
    The the only possible problem would be if the motorola charger was wired differently. However I have been using my razor charger to charge my Emerson 2GB mp3 player w/no problem.
    Plug in the charger with the mp3 player powered up, you should see the battery icon filling up just as if you were using the usb charger.
    if you are still to worried to try it , then get a voltage meter and test the polarity (weather positive and negative are the same on the motorola charger as the usb cord when plugged into the computer.
Sep 04, 2008 | MP3 & Digital Media Players
New Battery Charge?
This means your unit does not see the battery and is running on AC power only. You need to check and make sure that your battery polarity is correct making sure that positive goes to positive, and negative to negative. If you can attach some photos, that might help also.
Aug 13, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Misplaced charger
Answer: 5.0V, 1.5A, center positive.
Jul 17, 2008 | Entempo Spirit 20 MP3 Player
Archos gmini 402
Output 5v=0.75A
negative exterior, positive interior
Feb 13, 2008 | Archos Gmini 402 Digital Media Player
Album covers
There is no album art on this, hace to wait for the update maybe...
Dec 27, 2007 | Philips GOGEAR SA6045 MP3 Player
Nixvue Digital Album II MP3 Player Logo
Top Nixvue MP3 & Digital Media Players Experts
Are you a Nixvue MP3 and Digital Media Player Expert? Answer questions, earn points and help others
