Question about Mattel Disney Princess Bath Beauty Color Change Ariel 2007 - New
The tail on my doll is broken
The top of the tail with the shell is broken but the rest is fine. Except for the fact that there is super glue stuck on a place above the tail
How do I repair Celluloid dolls?
This repair guide will teach you how to restore a shattered celluloid doll. I will be taking you step by step through the process of restoring a Madame Hendren Baby Brite doll head.
What you need to get started:
1. Loctite Brand Epoxy Putty
2. Probond Brand polyurethane glue
3. cloth cut in 1"x 3" strips
4. Paper plate (Must be paper)
5. Loctite brand super glue
6. One package x-fine sandpaper
7. Paint (I use Createx brand in my airbrush)
Mar 17, 2017 | Toys
RC Silverlit SkyEye helicopter tail rotor broken off
P12 Try using 2 part epoxy(Glue) to make repair, it is worth a try, pretty strong just let it set up and cure well before using helicopter.
Apr 23, 2016 | RC Toys
Woody doll
Use clear super glue.
May 05, 2014 | Toys
How do I change the tail rotor on a syma s107
Carefully, while holding the silver metal motor in place, gently pull the rotor off of the rear drive shaft. Place new one on and push it gently into place. If it is loose, you can secure it with a VERY CAREFULLY applied mini-drop of super glue. Turn helicopter upside down and use as little glue as possible, keep it away from where the shaft meets the motor, and keep upside down until glue dries fully.
Hope this helps,
PvT
Jul 21, 2011 | SYMA Toys industrial New Syma S107 Mini...
How do I rmove and replace the tail rotor?
Hope this helps,
PvT
Jan 12, 2011 | SYMA Toys industrial New Syma S107 Mini...
How to replace rear rotar
Just the rear rotor itself? Or the motor as well?
Tail rotor pops right off, and replacement will pop onto the shaft easily. A small, very carefully applied, drop of super glue will keep tail rotor on firm. If doing that, I recommend you turn the helicopter upside down and then pay close attention that you don't get any glue near where the shaft meets the motor, and don't turn it over again until glue is totally dry.
If the motor needs to be replaced, you'll need soldering equipment, it's a really simple wiring job, but the wires are barely thicker than a hair and not very easy to access. Not recommended unless you're very confident with a soldering gun.
Hope this helps,
r
Jan 03, 2011 | SYMA Toys industrial Syma S032 Ready to...
The bose emblem came off onthe left headset that was holding the left ear set on the inside pcs loos fine but the emblem side is broken.Is there a space emblem with the female part for sale?
Difficultt ot get one except from Bose Corp. I suppose you could have used a instant super glue to past this up. if the earpieces are working fine why not try to do it carrefully as you mentioned it has come off, it can be wedged together with an instant glue. clean the surface and do the process.It should work out economical. I hope it works and looks fine. Good day
Jul 07, 2010 | Bose 41213 Headphones
A toothpick is stuck in the ignition switch. how do I remove it?
This can be tricky, but do it carefully and you can be driving in just a few minutes. If the toothpick isn't wedged super tightly in there, you can take another toothpick, break it in half, and put some wood glue or super glue on the broken end. Hold it against the stuck one until it's bonded, and gently pull it out. Super glue will work best, but you'll have to be really careful not to glue it to the ignition itself. If this doesn't work, you'll have to remove the ignition switch to get it out. Good luck.
Dec 06, 2009 | 1995 Toyota Tercel
Frigidaire Washer GLTR1670AS0: broken shocks + chipped rear shell
Check the diagram for the part you described as missing a chunk, it might be possible to get it as a replacement part for not much money. I would caution against trying to use any type of "super glue" since it doesn't have the durability to withstand the repeated shock and vibration that this part will experience. If the broken part is item #22 (shell/rear bearing) then the cost for the part is $170.00 - check the diagram to verify what your broken part looks like at the following link:
(copy and paste the entire string, as the hyperlink doesn't always load on the fixya site)
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GLTR1670AS0&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00003&componentDescription=WSHR TUB,MOTOR&documentId=R0111530&backToLink=Return to Sub Components list
IF I was going to attempt to repair (glue) the part, I'd use something like JB Weld for plastics as it would likley provide better results and I'd try to keep the inside as free as possible of any excess so as not to snap clothes, etc. Good luck to you and hope I've helped.
Jul 28, 2009 | Frigidaire GLTF2940ES Front Load Washer
Shell shocker remote not working anymore
On the back of the remote is a battery compartment for a 9V. Push the gray tail like piece in the center so that it slides and lifts open. l
Dec 14, 2008 | Tyco Radio Control Shell Shocker
Mattel Disney Princess Bath Beauty Color Change Ariel 2007 - New Logo
459 people viewed this question
Top Mattel Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Mattel Baby Gear Expert? Answer questions, earn points and help others
