Question about Pioneer Vsx-1022-k 7.1-channel 3d-ready Network Home Theater Receiver
No sound For no apparent reason, we have video, but no sound.
Yamaha RXV 1400 RDS and subwoofer stopped working
If it is new, just send it back for warranty repair.
Jan 13, 2014 | Audio Players & Recorders
Volume levels vary for no apparent reason. From normal to quiet and back at what seems to be random time intervals. No jiggling of any wires makes a difference. The speakers are old and I'm wondering if...
If you are using it to watch cable TV stations, They may have different audio levels between programming. Also you want to check and not use dolby when atching standard TV channels
Jan 19, 2011 | Audio Players & Recorders
My psp says that the disc is unreadable on multiple occassions for no apparent reason when the game works fine in my cousins psp
Sounds like there is a problem with the disk drive in your PSP. Open up the disk tray and look for the laser. Take a (very) damp q-tip and lightly clean the laser and gently push the laser center. If this does not work you will need to replace your PSP laser or send it in.
Jan 07, 2011 | Sony PSP (Piano Black)
When i turn Studio 11 on and connect my Dazzle recorder (which is a Platinum running on a dvc 100 Driver for some reason) the sound plays perfect but i get black screen with no video and Studio 11 tells me...
Apparently you have to download the dvc90 drivers, im trying to now but i dont know how to change the drivers for the actual thing.
yeah im a noob. hope that helped in some way.
Jul 11, 2010 | Computers & Internet
2004 mercedes c240 alarm sounds for no apparent reason
Hi, You need to replace the alarm siren. It is also a module. It is located in the right front fender well. The reason they go bad is because they are located in a place where they get wet.
Apr 03, 2009 | 2004 Mercedes-Benz C-Class
Vcr playback sound interruptions
Please get the VCR check by any local technician. Since the sound is dropping intermittently it is a hardware issue
Oct 07, 2008 | Computers & Internet
Lost audio for no apparent reason
Try unplugging your HDMI cable from the AVR I would like to see if your AVR is trying to use HDMI out instead of the composite. Next try plugging each device directly into your television, this will isolate the issue and tell us for sure whether or not it's the AVR.
Jul 10, 2008 | Denon AVR 2808Ci Receiver
Sound gone
disconnect everything in the back of the unit. reconnect only the cd to the imputs. also,just to be sure, disconnect all speakers(label them). fire it up,play a CD, connect the speakers 1 at a time. If the 1st works you have hope ,if not, try each channel individualy.The one that reduces volume is the problem-maybe shorted cable, bad speaker,or , God forbid-Bad amp Channel. good luck
Dec 30, 2007 | Yamaha R-V1103 Receiver
Onkyo TX DS797 no sound from cable TV
Have you made sure the receiver's INPUT SELECTOR is set to "Video 2"? I know it seems like a stupid question, but worth mentioning as many folks would set the receiver on TV, which would not work unless the signal was also plugged into a "TV input" in back of the receiver. If your setting is correct, try running the TV cable sound temporarily into the receiver's DVD input, which we know does work. If you still don't get cable TV sound when the receiver is set to "DVD", then you have a problem with the TV cable audio portion. Most receivers would fail completely, rather than have only one input fail, so my guess is that there is a hookup or switching error somewhere.
Feb 15, 2007 | Onkyo TX-DS797 Receiver
Pioneer Vsx-1022-k 7.1-channel 3d-ready Network Home Theater Receiver Logo
15 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
