Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
My 46H83 46" toshiba tv will come on and play for a few minutes then the screen and sound go to glitching and then it quites showing any picture at all. Would love to know what part to replace????
  • 1 more comment
  • deersick Dec 28, 2009
    The last few times i turned it on there was no pic or sound at all. it powered up but no picture
    where do i find the power supply board and part number on my tv so i know what part to order?
    yea. I just need to know where the part is located on my tv so i can replace it.
  • 3,741 Answers
Its the fault in the power supply board . initially unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short tracked within few minutes of working. in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper. to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
also you can get new replacement power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Dec 28, 2009
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
Screen goes blank on toshiba 42hl167. sound still works, and turning the tv off for a few minutes restores the picture.
your tv's pictures tube are creating the problem. contact with the tv brand customer services center for the repairment of your tv
Jan 06, 2011 | Toshiba 42HL167 42 in. LCD Television
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
Aug 23, 2009 | Toshiba 42HP95 Television
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Sony KV34HS420
Always go through the basics before you post questions.  All I did was reset the TV (unplug for a few minutes) and it is back to normal.  Lesson learned, TV fixed, thanks.
Feb 15, 2008 | Televison & Video
Vocopro Gig Man won't play
we're having probles.we have avhf-4800 from voco pro,lights come on the box and on mikes no sound on teo mikes
Jan 09, 2008 | Audio Players & Recorders
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
