Question about Dishwashers
POSSIBLE THAT A PEANUT SHELL FELL IN DISHWASHER. MAKES UNUSUAL NOISE WHEN CYCLING. ALSO WATER SPRAYER IN BOTTOW DOES NOT MOVE.
    Problem Solver:
  • 17 Answers
There is a split pump system on these appliances so it looks like the said peanut ?has blocked the flow to the bottom spray arm solution is to remove the circulation pump and clean out
Posted on Jun 15, 2009
The water is still in the bottow of the dishwater and the cycle is in the heating mode. The dial is making noise as if it wants to move forward, but it can't. It stop well before the heating cycle...
Have you recently installed a garbage disposal? If so, you probably didn't knock out the plug where the drain hose from the dishwasher attaches to. Just disconnect the hose from the garbage disposal, use a punch or screwdriver and tap it out with a hammer. (Don't forget to remove the plug from the grinder area) Then reconnect the hose.
Jun 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Whirlpool dishwasher makes a loud notise then
The spray arms do sometimes wear and need replacenent, and are available fron spares centres.
The loud noise is probably the water pressure pushing it off at an angle, and instead of rotating, water will just escape out one side - so your dishes will not get clean untill it is replaced.
Aug 05, 2009 | Dishwashers
GE Dishwasher makes loud banging noise
Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
Apr 06, 2009 | GE Dishwashers
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
GE Triton XL Dishwasher not cleaning glasses
Check to see if the spinner holes are clogged with food..or debris...this is what makes the sprayer arms move....water pressure...which is pumped up through the sprayer arms .......I s the pump working...if so....then you may also have some blockage at the base of the pump where the screen is that keeps impurities out of the pump....check to see that food or debris is not obstructing this.
I hope this help....have a good day and good luck...please rate my effort...the Fang
Dec 14, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
The top sprayer fell off
Hello kitzant,
Please use the following link that shows an exploded view and parts list for your dishwasher. Note items #568,569 & 570 that depicts the hardware stack up for the upper arm.. Hope this helps..
Here is the link: http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 07, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dial not moving/not cycling through
If the dial won't rotate then you need to replace the timer.
Mar 30, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
On certain cycles, the motor makes a very loud humming noise.
quite possible that noise is from foriegn debris( ie.chicken bone of pistachio shell, toothpicks) getting into macerator/chopper assy, wouldnt panic just yet, give it a fewloads to try to clear itself, a few screws leading down through the top of motor assy (under lower spray arm should give you access to assy if needed
Feb 22, 2008 | Amana 24 in. DWA22A Built-in Dishwasher
Dishwasher not spraying
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
Sep 12, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
