Question about Bass Pro Shops XPS 12V Phase Charger
Xps charger power light is flashing
Why will my dell xps not turn on
Did it do the shutdown process or just all of sudden go black? I would try another power adapter/charger sometimes they just go bad. If you know the adapter is working and you get no lights @ all its probably something internal like the power jack or motherboard.
Jul 11, 2014 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Dell xps gen 4 diagnostic lights A C D green B amber also front power light is flashing green and amber
go to dell website and see what those lights are meaning, I can't help with no exact brand and model (Dell - model ....)
Feb 19, 2014 | Dell Dimension XPS Gen 4 PC Desktop
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Xps 17 battery charger
I think either you have the wrong DC Power Jack installed (where the power cord plugs into the computer) or the wrong AC Adapter & Power Cord.
Hopefully you have an AC Adapter Power Cord that was made for your computer and not one of those one size fits all that some stores sell with the interchangeable tip at the end that plugs into the computer.
Mar 30, 2012 | Dell Xps 17 Laptop Computer (Intel Core i7...
Battery installed power shows but not charging battery, new battery and charger. thanks.
Hi
Its a common issue for DELL Laptops usually if the battery and charger are working fine the culprit is the motherboard. If its still under warranty have them replace the motherboard and it will be good as new.Thanks
Feb 08, 2011 | Dell Inspiron XPS Series Notebook: XPS...
My battery has been out for a year and I use my lap top with the charger only . The laptop holds no charge and it flashes orange. Has this hurt my computer? I have a xps m1210. A suggestions for a battery...
No your PC is not hurt. The problem is that you motherboard is having problems reconizing the charger. I recomend calling Dell Costomer Service and telling them you problem and have them replace the motherboard and or battery.
Jul 09, 2010 | Dell XPS M1210 Notebook
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
The power light on my Dell XPS 8000 keeps flashing
It's not the light.Your CPU might be already dusty. I also had an experience that was just like you. I just cleaned up my CPU and the noise was gone.
Feb 12, 2010 | Dell Studio XPS Desktop Computer
DELL XPS 700 AMBER LIGHT
you don't tell us from where coming the amber light from the cpu or from the monitor?
May 29, 2009 | Dell XPS 700 PC Desktop
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Bass Pro Shops XPS 12V Phase Charger Logo
Top Bass Pro Shops Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Bass Pro Shops Boating Expert? Answer questions, earn points and help others
