Question about Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio Stealth Pro Metal 9.7" 8gb 4.0 1.2 Ghz Android Tablet
My android stealth tablet freezes up or i can be on a web site and it goes back to home screen without me pushing any buttons
Freezes up or goes back to home screen on its own
Tablet does not completely come on when activated.
mine either but ...... that means that your battery bar is not full even though it says is it.Or ur tablet does not hold its charge
Mar 20, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Removing duplicate widget from Android tablet homescreen
Keep your finger on the widget until it changes colour then drag it to the waste bin on the screen and let go. Depending on tablet,software etc waste bin could be centre top of screen, taskbar bottom of screen or at the side but it will be there.:-)
HTH
Jan 09, 2014 | Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio...
Just purchased a trio stealth pro tablet, charged it overnight and I turned it on and all it's does is flashe the little martian icon for about 2 minutes then the screen kind of goes dark and nothing...
Sorry to hear this. you are not the only one and kathy there are some things you can try. I have been trying to figure out why and what is the root cause. I will pass on to those who get THE BRICK some links and things to try. But i will not give u all the info without this.. TAKE MY LINK AND GO BACK TO WHERE U GOT IT ASAP AND EXCHANGE OR GET REFUND...U CAN USE MY NAME AND FIXYA LINK IF NEED..HERE U GO.
http://androidtabletnotworking.com/
http://youtu.be/mb8caOVjN1M
I
Oct 07, 2013 | Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio...
My trio stealth g2 won't turn on the battery drained last night so I put it on charge and in the morning I took it off and I pushed the power button and all it said was trio stealth g2 and it thats all...
there are several things u can try to reset it. but i have not seen many of reset and continue to work without having other problems. check out this link first.
http://youtu.be/jcreuqRxK6w
there is a reset on the back of the tablet..l use a paper clip and push the reset button and hold it until it turns off and then push the power and the sound buttons together ..sound button up. if this does
work use the power cord to charge it. if this fails return it with the link i use above..
good luck
chad man
Sep 01, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio Stealth Pro Metal 9.7" 8gb 4.0 1.2 Ghz Android Tablet Logo
21 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
