Question about Dynex EN-21669D Remote Control 1061531
Dynex EN-21669D Remote Control need to fix
Don't work power wont turn on light doesn't work its dead
  • 718 Answers
SOURCE: my volume control on remote doesnt work
Try the following first;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If you are still having problems, you should return the unit to the place of purchase for a replacement.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: I need the dynex tv code for a comcast remote control
Try 10463, or the Emerson tv code.
Posted on Apr 09, 2009
SOURCE: cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
Posted on May 24, 2009
budmrtn
  • 11361 Answers
SOURCE: 32" Dynex No Power, Power on/off light will not light up
Check the power supply module first for blown fuse, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 12, 2009
SOURCE: my dynex remote control for 32 inch flat screen
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Posted on Mar 28, 2010
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
I have dynex en-21669d universal remote how do i set up my Pioneer dvd/cd receiver ?
Instructions should have come with the generic remote but often generic just do not work with many systems
Oct 14, 2014 | Televison & Video
Dynex 40" model DX-L40-10A tv remote control En 216690
Codes to check with Dynex brand TVs are 0853,0875,0828,0816,0842. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and proceedings to some popular model remote control are given.
Mar 04, 2013 | Televison & Video
Tv will not power on. We don't have remote; but have tried using the side buttons with now luck. 803-331-0904
If the TV DOES have controls for manual use, and doesn't turn on with those, the control board (either) blew a fuse and is completely dead, or there's damage from outdoor weather. Most likely, the control board is dead, and the best way to fix it would, sadly, be to send it to a local repair shop. If you don't think its worth the approximate $200-$300 to fix, a new one is the simplest solution. I really hope this helped.
Oct 06, 2012 | Televison & Video
CEILING FAN WORKS,BUT REMOTE ONLY WORKS THE FAN SECTION, WILL NOT DIM LIGHTS NOR TURN OFF LIGHTS ONLY SO WE CAN USE FAN ONLY. WHAT DO WE HAVE TO DO?
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
I am trying to get the code numbers for Dynex tv
Unfortunately the user manual does not have a pre-programmed code for Dynex, so your best bet is going to be performing a code search.
To search:
1. Make sure the TV is on
2. Point the remote at the TV and hold down "CODE SEARCH" for at least 3 seconds, until the red light lights up solid
3. Press the "TV" button once and the light will blink once, then return solid red.
4. Press the On/Off button repeatedly until the TV turns off (go slowly enough that you don't keep pushing on/off after the TV turns off)
5. Once the TV turns off, press the ENTER button and the code will save (and the red light should go off)
This may take a while, so be patient, but if anything should get it working with your TV this will be your best bet.
Aug 25, 2011 | Innovage Jumbo Remote Control
My dynex remote control for 32 inch flat screen stopped working, tried new batteries-no fix, any help? Can I use another or do I have to contact the company for a new remote?
Jan 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Nov 12, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
My t'v wont read my remote!
You will need to call the Dynex customer support and ask them for help with this problem. The problem sound like the television is having a problem with the main read controller for the remote control. This is a problem for a service center.You can call Dynex customer support at this telephone number 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of your television and the problem you are having with the remote control reading circuit. I hop this information helps you with your problem.
Apr 12, 2009 | Dynex DX-LCD37 TV
I have a philips 42pf7220a/37. when i turn it on the picture is fuzzy and red.
Any luck with fixing your Model#42PF9630A/37 as I am having the same problem with mine?
Thanks
Feb 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Dynex EN-21669D Remote Control 1061531 Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
