Question about Bose Audio Players & Recorders
Clicking noise Headphones making clicking sounds...I tried replacing the battery...did not help
  • 526 Answers
SOURCE: makes clicking/grinding noises when printing. just replaced drum but that didn't help. any ideas on what it could be? sounds like a gear perhaps?
Most likely, the gear in the fuser assembly is cracked. That is the most common problem with that unit. You can take the fuser out to examine if the gear is broken or partially broken before deciding to replace it. Lastly, check to see if the noise is happening at the rear of the printer, thats where the fuser is located.
you will need to Replace HR Gear34 in fixing unit and the part # is LJ7416001.
here is the info to do it, but I dont recommend it.
1. Disconnect the heater harness and thermistor harness.
2. Remove the bind B M4x12 taptite screw and the shoulder screw, then remove the fixing unit
3.After the fixing unit has been removed, remove the 3cup B M3x10 taptite screws and remove the FU paper guide
4. Remove the 3cup B M3x10 Taptite screws and remove the star wheel holder
5. Remove the cup B M3x12 Taptite screw
6. Release the thermistor assembly harness from the hooks
7. Remove the thermistor assembly
8. Remove the 2cup taptite screws
9. Remove the upper FU frame from the lower FU frame
11. Remove the heat roller 25
12. Remove the halogen lamp
13. Remove the HR bearing 25
14. Remove the HR Gear 34
15. Remove the HR retaining ring 25
16. Remove heat roller washer 25
17.Check the heat roller bearing 25 for damage. If damage is noticed replace the bearing and the Hr Gear 34. The part # for the washer is LJ7414001
Posted on May 07, 2009
wadembly
  • 513 Answers
SOURCE: 20a fuse replaced, makes a clicking noise when
the starter could be bad take a medal hammer tap on side of starter see if that help if it works & starts then the starter is going bad & may need to be replaced but you can also have a bad starter sylinoid
Posted on Jun 27, 2010
  • 1833 Answers
SOURCE: i have a 2005 jeep grand cherokee and the
You can try with replacing the head phones. If it doesn't change anything, then the problem may be the device's internal problem, then there is no other way, but to repair them.
You can get more information in detail here; " www.
intractable.com/.../How-to-wire-a-headphone-jack-to-a-speaker/ -", " www. Bose-speakers.org", " www. Techimo.com".
Posted on Mar 25, 2011
  • 2006 Answers
SOURCE: When I try to start the car it makes a click sound
Did you also change the starter solenoid when you changed the starter? That is a possible cause.
Can you turn the engine over by hand from the crankshaft pulley to make sure the engine is not frozen or blocked? You will need a large socket to do that, but if you can't turn the engine over by hand, the starter won't be able to turn the flywheel either. The one click is probably the solenoid firing the starter piston to the flywheel but then nothing makes me think the engine is frozen in some way.
But if the starter and solenoid and battery is trying to turn a frozen flywheel, you should notice some drawdown of light intensity. Do you notice any change?
Posted on Jun 06, 2011
Testimonial: "Great advice!!! Thanks for all your help!"
SOURCE: Clicking noise when starting
Most likely you have a bad started. Have your battery load tested to verify that it is ok first.
Posted on May 16, 2013
Clicking noise when trying to start, replaced battery and starter. Still makes clicking noise. Can someone please help me figure out what is wrong?
Did you clean your cables? Sounds like a bad connection if you have a new battery and starter. Make sure your ground connection from the battery to frame is clean and tight as well.
Jan 22, 2016 | Cars & Trucks
Why do I get only static on Sennheiser 120 after replacing the batteries?
Sorry I have not had that problem with batteries but have had other noises and I usually stop using the headphones for a while and hang them up and start again.
Jun 03, 2014 | Sennheiser RS 120 Consumer Headphones
What does the orange light mean on your sony pulse headset? And why doesent make noises when its turend on?
check the cables to the base-transmitter station. If they are firmly connected or try to replace them. Most of the wireless headphones of some more advanced design detects incoming signal and switches to mode on wich indicates with another color when the sound dissapears the headphones detects no sound and goes into a powersaving mode. Usually the headphone itself doesn't fault very often, cause they are battery powered and the powersupply isn't wavering like the powertransformer to the base-station due to the irregular power from the ac outlets, wich is why any electronics should be connected to a surgearrester list.
Another thing to check for is there any sound coming from the tv/game connector, try to connect a nother speaker assembly or headphone or if the connector is of a low signal type, a amplifier with speakers or headphone make sure you don't have to much between where the sound comes from and the headphones. Let me know if some of my advice helps you!
Jan 25, 2013 | Radio Communications
Just started making "clicking" sounds with a deep
Mine did this also. A regular popping on and off of the Noise Canceling feature, making it impossible to hear music/sound. If while this is happening your green battery indicator light is flashing on and off with the rhythmic popping on/off of the NC, try replacing your AAA battery with a new, fresh battery. I did, and all was well again. I had to do this twice since the first replacement battery came out of the TV clicker and were too warn to fix the problem (ran out of AAAs, it was raining, and late at night, etc...you know the Emergency battery replacement drill - run around the house shamelessly cannibalizing the kid's toys, Grandpa's insulin pump, the wife's ********...whatever you can find). Anyway, the next day I sprung for a new set of Energizers and all was well with the world again. Hope this helps.
Feb 22, 2011 | Bose QC15 Headphones
Sennheiser RS120 with noise...
Couple of things could be going on..
Try the obvious first
1. Select a different channel on the base unit: Located on the front, under the logo is a small switch. Note the position and try the other two settings
2. Make sure your base unit is not next to other items that may interfere with it.. cordless phones and wireless network routers etc.. microwaves or other RF sources .. fluorescent lamps.. etc
Lastly.. just about all wireless headphones have some noise or background hiss.. but it should be minor.. if the rechargeable batteries are not taking a full charge or cannot retain the charge properly.. the reception will also weaken.. and that noise will increase.. and the reception distance will decrease.
You can buy a new set of rechargeable batteries .. just make sure they are exactly like those in your headphones..
If I remember right.. they are Nickel Metal Hydride… (NiMH).. Radio Shack will have them.. or a store like Batteries Plus.. If you replace them.. go for a slightly beefier battery.. a higher mA-h.. may take a bit longer to charge initially.. (If you try this.. remember.. they will need to charge overnight before use) but will “play” longer in use.
It has been noted that many of these headphones shipped with inferior batteries.. that problems seems to have been addressed by the mfg.
Good Luck!
May 17, 2009 | Sennheiser RS 120 Consumer Headphones
The sound just stops dead
I have the exact same problem. Try to crank up the volume from your stereo/receiver and lower the volume in the headphones. I think that the headphones goes into standby mode if the volume is to low. Works for me (for two days, so its not really a fact yet ;-) )
Feb 24, 2008 | Sony MDR-RF970RK Headphones
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
