Question about New World E90DOa Electric Double Oven
How to change the time on a new world cooker
Only has 3 buttons - funtions and +
New world cooker classic 100DF.Glass door outside glass shattered. Looking for new one.
Fixya is unable to suggest sources for New World cooker parts.
Apr 12, 2018 | New World Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
Dec 23, 2009 | New World G60m Gas Single Oven
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
Lost the manual for a new world cooker
To get a new (pdf) manual ask at http://manualfox.com - they find you every manual.
Jul 31, 2009 | Ovens
Can not set clock
For the NW09DO, press the outer two buttons ("-" and "+") together and hold for three or four seconds. Then press "+" to advance the clock/time and "-" to go back.
When the correct time is showing, leave the buttons alone for four or five seconds.
Feb 19, 2009 | New World E70DOa Electric Double Oven
New World E90DOa Electric Double Oven Logo
53 people viewed this question
Top New World Ovens Experts
Paul Carew
Oloyede Monsuru
Are you a New World Oven Expert? Answer questions, earn points and help others
