Question about Logitech Webcam
I have an oldlogitech ball that still works ,but i want the higher def c270 that i just got ,set up . how do i do that?
I cant get my new Logitech c270 to work.
Start up for logitech c270 manual and pdf
To help you setup and configure your Logitech C270 HD webcam, please follow the step-by-step instructions mentioned on the link given below:
http://www.logitech.com/assets/31702/2/c270620-002802003403gsamr.pdf
GuruAid.com
Mar 27, 2016 | Logitech Computers & Internet
How do i adjust the zoom control on the logitech C270 so that i can use the pan and tilt functions?
Do any of you have Follow my face option enabled while trying to use the Pan and Tilt feature? If so, please disable it and try using the Pan and Tilt feature again.
Aug 23, 2014 | Logitech C270 Web Cam
Why do we hear what sounds like a train travelling between us
The V-UAP42 is a bit old. Old devices tend to have problems internally. I would suggest getting a new webcam, preferably a Logitech C270.
Aug 05, 2014 | Logitech Quickcam Chat Webcam
Youcam software
I suggest you download the latest driver from here: http://www.logitech.com/en-us/support/hd-webcam-c270?osid=1&bit=32 and then try an other software to captur the video change the viseo settings this should resolve the issue. Also kindaly tell if you are trying capture the video from the screen because in that case it might not work try making a video off-creen for video from the screen you can use a screen capturing software instead of teh web cam.
Sep 22, 2013 | HP Computers & Internet
C270
Uninstall first the go to Logitech and grab the latest driver for your OS.Post back!
Jul 16, 2013 | Logitech Computers & Internet
Webcam wont work
I ran into the same problem you did with my Toshiba running XP windows, I got my son who has his A certification in computers and it took him 4 hours to get it to work. I suggest you go to www.logitech.com contact customer support and the technical department.
Jun 03, 2012 | Toshiba Satellite Computers & Internet
I can,t seem to get it install.
Logitech drivers are available from their WEB download site- click on this link and select your model WEBcam to download : - http://www.logitech.com/en-au/support-downloads
Jul 01, 2011 | Logitech C270 Web Cam
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
