Question about Riccar 1500. 1700, 1800, Pristine, Starbright, Charisma Canister Filter Vacuum Bag Antimicrobal 6
Is there a reset button
The machine just stopped running and will not turn back on
  • Riccar Master
  • 1,320 Answers
The reset button is internal. If it overheats it will shut off but will come back on when it cools down. This usually means you have a clog somewhere or a clogged bag or filter. If that doesn't take care of it have it checked by your Riccar dealer.
Posted on Aug 11, 2014
Panasonic vacuum cleaner just stopped running
Set the on/off switch to off, now check near the top of the "beater" portion, I think that model has a reset button, you should hear a slight "click" when depressed. Try turning the vacuum back on.
Aug 26, 2014 | Panasonic MC-V5217 Vacuum
Reset button inoperative
Sounds like 1 of 4 possibilities
1.The button next to your on switch is jammed.
2. The Motor has burnt out within the head unit
3. The PCB Unit is faulty wihin the head unit
4. The thin wires running down the inside of the machine to the head unit hve br
May 23, 2014 | Dyson Dc-18 "slim" Upright Model...
Brush doesnt turn
Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
this link is for the manual..
http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_allfloors_uk.pdf
Sep 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuum stopped working due to clog. Clog cleared vacuum won't turn on
There is a reset button on the back of this machine that acts as a circut breaker. Push that back in and it should go.
Nov 26, 2009 | Hoover Elite Rewind Bagless Upright...
Dyson Animal 17 - brush stopped turning
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin, press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
Jun 24, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Electrolux 2100 hot motor light came on because hose was plugged
The thermal switch should reset itself after it has cooled. If it still won't restart after a while longer, put a a new bag in the machine and turn the machine off and back on. The only other things that should keep it from running other than the thermal overload, is the bag being full or the bag not being present. Either of these faults would need to be corrected and then the machine switched off and back on to clear them. I hope this helps. Good Luck!!
Jan 03, 2009 | Electrolux Epic 6500 Vacuum
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
The vacuum stopped running and won't turn back on?
While there's no reset button it's not uncommon for the internal thermal switch to trip to an "open" position. This internal, no-access-switch opens when the motor gets hot, it protects the motor from overheating to the point of failure. Bissell's website states that if the thermal switch is tripped let the vacuumm sit for a half hour and then it try it again.
If it doesn't work you might then try Tech610's suggestions.
Dec 08, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Where is the reset button on the electolux 2100
There is no reset button on the 2100. If it shuts down, the indicator lights will tell you why. If it has been overheated, there is a self-resetting switch which will shut the motor down and the light will come on to indicate that particular problem. When you turn the machine off and then back on, it should re-start provided you have given the motor ample time to cool down. This will not solve the problem as to why it overheated in the first place. There are also lights and auto-switches that will control full bag and no bag. The machine will not run with no bag and a full bag will cause it to run for a few seconds and shut off.
Mar 20, 2008 | Vacuums
Riccar 1500. 1700, 1800, Pristine, Starbright, Charisma Canister Filter Vacuum Bag Antimicrobal 6 Logo
152 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
