Question about 1996 - 1997 GMC K3500 Radiator Coolant Hose W0133-1631411 Upper
Petcock location for a 1996 k3500
Location for petcock
Where is the 1996 Oldsmobile cutlass supreme petcock located?
Well the only petcock that comes to mind is the radiator drain petcock. It would be located in the bottom of the radiator plastic tank, at either the right or left end on the engine side. Many times the tabs that you use to turn it with are broken off, making it harder to see where it is. If you are going to do a coolant flush, just disconnect the lower radiator hose to drain the coolant; it is faster!
If this is what you are doing there is a vent screw in the top of the thermostat housing to let out air when filling the system. VERY IMPORTANT TO DO. I hope that this answers your question.
Mar 02, 2017 | Oldsmobile Cars & Trucks
Where is radiator drain plug on a 1996 toyota corrolla
Look on the lower end of the radiator going toward the engine on the passenger side. You should see a petcock, which is a drain valve. Put a container under it and turn it counter clock-wise.
Jan 08, 2015 | 1996 Toyota Corolla
How much Engine oil do i need on my 96K3500 Turbo Diesel?
7 to 8 quarts of oil needed for k3500 diesel.
Feb 24, 2012 | 1996 Chevrolet K3500
1996 gmc k3500 dually 4x4 dump truck-front axle won't engage-very little power if any to front electric plunger on front axle to engage 4 wheel-checked fuses-they're good--is there a relay & where is...
have a 95 k3500 4x4,when i shifted to 4 hi,would not engage.never once heard any type of noise in the front end.replaced both actuators,fuse is,front will not engage.please advise.ken at 989-560-1906.or cobbish44@yahoo.com thanks
Jan 11, 2011 | 1996 Chevrolet K3500
97 k3500 7.4 how do i get the distributor off to replace? cant get at screw under intake manifold.
I would stop at your local parts house and buy a cheap distributor wrench. It is L shaped at the bottom and makes it alittle easier to get in there, either way its not easy.
Dec 02, 2010 | 1996 Chevrolet K3500
K3500 hydraulic brake booster engages brakes when
hello there:
You will need to replace the brake booster to correct the problem in order to do this you will need to remove the push rod from you're brake arm separate the master cylinder from the booster and remove the four bolts on the booster and slide it out install in reverse hope this help you out sincerely D.Jones
Jun 12, 2010 | 1996 Chevrolet C/K 3500
1996 vortex 7.4 l chev k3500 turns over but acts
think its time for a rebild-local library sec629 has the books in detail
Jun 01, 2010 | 1996 Chevrolet K3500
Need location of computer for 1997 gmc k3500
Hello Charles: My name is Roger and I Will help. The PCM is located behind the glove box on top of the heater case. The VCM is located under the hood just above the ABS unit. Should you need further help please just ask. Please rate the answer you received. This way I know the answer was helpful. Thank You for using Fix Ya. Roger
Nov 18, 2009 | 1997 GMC Sierra
Radiator flush
The petcock is the bottom drain in the radiator.Turn it clock wise to tight..Its on the bottom drivers side of the radiator.Hope this was helpful.Have a great day..
Apr 02, 2009 | 1996 Chevrolet S-10 Pickup
1996 - 1997 GMC K3500 Radiator Coolant Hose W0133-1631411 Upper Logo
12 people viewed this question
Top Gates Vehicle Parts & Accessories Experts
Lodhi Autos
Lodhi Autos
Walter Turteltaub
Level 1 Expert
Bill Boyd
Are you a Gates Vehicle Part and Accessory Expert? Answer questions, earn points and help others
