Question about Honda Garden
Gas is coming out of hole in float bowl - Honda Garden
    President:
  • 1,111 Answers
There shouldnt be a hole in the float..if there is, the float is shot...the gas can never shut off if its filled with gas
Posted on Jun 20, 2009
6.5 gas was coming out of air side got the carberater apart and the flot has something in it like gas or water is that ok?
if your saying that u took the bowl off the bottom and you got water out of it no that's not good , there should only be fuel in there , the brass ring float should pivot freely to allow or disallow fuel to enter bowl as it drains out , and yes if bowl overflows due to a hung up float gas will come out air intake hole try not to turn engine over till carb float issue is resolved due to it ingesting liquid fuel into cylinder and causing pop back , this can and will cause a fire !!
Aug 25, 2015 | Briggs & Stratton Garden
I have a briggs and straton1150 seris 250 ohv wont start no gas to the cylinder
Take the bowl off the carb and make sure the float allows fuel to fill the bowl when the float is in the down position. If not you have to remove the needle from the float and use a thin wire go up in the seat to unclog it. If it is getting fuel to the bowl you have to clean the center jet inside where the bowl nut screws in to and make sure the bowl nut hole is clean. The bowl nut also should usually has a hole in the side of the threads which should be cleaned.
Feb 19, 2015 | Briggs Electrical Supplies
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Lawnmower carburetor problem.
Remove carb float bowl. Check float operation. Float down gas flow, float up no gas flow. Clean float bowl. Observe bowl screw, see if there is a hole or holes thru the screw. Clean out with thin wire, bread wrapper works peeled back about an inch. Use wire to clean out center port of carb. Remove mounting pin of float, remove float and meter needle, clean out port up thru carb with wire. Reassemble try to start. Prime at least 3 times, ensure primer bulb is not cracked, replace if cracked. Replace air filter if dirty. Replace spark plug once a year. Fill oil. 30w. Mowers now have a low oil cutoff.
Jun 14, 2013 | Garden
Toro 20624 mower runs rough
Remove float bowl from carb. Ensure gas flows with float hanging down. Ensure gas flow stops with float pushed up.. Remove float and meter needle. clean passage way were meter needle is inserted with a bread wrapper wire, with 1 in of plastic peeled off it, wire should be observed behind choke flap when fully inserted thru passage way. Replace float and meter needle. Clean float bowl. Observe float bowl screw, look to see if it has a hole thru it, if so clean with wire. Reinstall float bowl. Try to start.
Jun 17, 2012 | Toro Garden
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
How to take apart and clean carburator.
remove air filter and see if your carb has a float bowl on the bott. of it, if so remove bolt on the bottom center and carefully pull the bowl off next clean the bowl out with carb cleaner, then the nut that holds bowl on has tiny holes in it, take a bread tie wire and carefully clean these holes out, then, lift your float up slowly and see if gas quits running out of carb, then lower the float a
nd gas should start running again, then carefully put bowl back on and tighten up nut on bottom and put gas in.
Jul 30, 2011 | Toro Power Lawn Mower
Just bought a 82 xj650. It has some flooding on the right carb. any suggestions? Gas comes out the right side exhaust, also dies after running about 10 to 15 minutes.
Yes.
1.Remove the Float Bowl, (Turn gas off first), and clean the crud out of the bowl. (Bottom of the carburetor)
There is a brass nut in the middle of the float bowl, which is on the bottom of the carburetor.
There is a fiber, or brass washer on that bolt. DON'T lose it! (Turn it to the left)
The brass bolt, (Main Jet Plug), goes through the float bowl, and into the Main Jet.
Remove the float, (Carefully! If it's a plastic designed float, Don't nick it with your fingernail/s. Also make sure it isn't soaking up gas. If so, {You'll know!}, replace it)
A.DON'T let the float needle valve fall out, when you remove the float! The Float Needle is attached to the float, with a small 'hair spring' clip.
B.DON'T lose the tiny, 'hair spring' clip, that attaches the float needle to the float.
Observe VERY carefully how this tiny spring clip goes on the float, ->Before you remove the float pin. (The float rotates up, and down, on this long round pin) It has to be put back the same exact way)
Handle the float with extreme care. It is set to a certain height. The measurement goes from the bottom of the carburetor body, (Where the side of the float bowl touches), to the top edge of the float.
The top of the Float Needle has a groove cut around it. That 'Hair Spring' clip I described above, clips in this groove. The other end of this 'Hair Clip', goes around a flat area that extends out of the side of the float.
Once you get the float bowl down a bit, you'll see what I'm referring to above.
C.The Float Needle Valve is made of metal, and has a Neoprene, (Like rubber), tip on the end. The Neoprene tip is cone shaped. A light little ring mark on the Neoprene tip is okay.
If the tip is broken, or mushed out, the Float Needle Valve is no good.
More than likely you just have crud in the float bowl, and it is also down in the Float Needle Valve Seat.
(The Float Needle Seat is a brass cylindrical shaped piece. It has a tapered hole inside, down at the bottom. Fuel, {Gas} comes through this tapered hole, and the Float Needle Valve regulates how much. The float raises, which raises the float needle valve. Fuel comes through the tapered hole. The float drops, which lowers the float needle valve, and stops fuel from coming through the tapered hole, and into the float bowl)
After time, the bottom of your gas tank develops rust, from moisture in the gasoline.
Dirt also finds it's way into a bike's gas tank. Also the additives in gasoline accumulate after a while.
If you do not have an inline fuel filter, I advise you buy, and install one. This way you change the fuel filter element, and do not have to tear the carb/s down again.
Aug 07, 2009 | 1981 Yamaha XJ 650
Craftsman 5.5 Gold mower will not start
YOUR PROBLEM IS SIMPLE.
FIRST OF ALL THE HOLE IN THE PRIMER BUTTON MUST BE THERE TO POP BACK OUT EACH TIME YOU PRESS IT NOW AS TO THE GAS COMING OUT OF THERE
THE FLOAT IN THE CARB IS STUCK IN THE FILL POSITION AND WILL NOT LIFT ONCE THE BOWL IS FULL TO STOP THE GAS FROM FILLING OR YOU HAVE A PIN HOLE IN THE FLOAT ITSELF.UNDO THE NOT ON THE BOOTM OF THE BOWL WITH THE LAWN MOWER TILTED ON A 45 DEGREE ANGLE SEE IF YOU CAN MOVE THE FLOAT UP AND DOWN IF IT IS FREE MOVING SPRAY THE WHOLE AREA CLEAN WITH CARB CLEANER AND REASSEMBLE TRY TO START ,IF STILL THE SAME PROBLEM YOU WILL NEED TO REBUILD THE CARB AND INSTALL A NEW FLOAT
Jun 26, 2009 | Garden
I am getting fuel leaking from the bottom of the carb and I have adjusted the screws on the bottom of the carb but it is still leaking...it is a 1997 flstf fatboy
Carburetors have a Float Bowl on the bottom. This float bowl has a small amount of fuel, that the carburetor uses. (The float bowl's amount of fuel, is replenished from the gas tank. The fuel is gravity fed from the gas tank, through the Fuel Line)
The float bowl has a Float Needle inside. The float needle is attached to the Float. The Float resembles a thick doughnut. On one end of this doughnut, is a flat piece of metal shaped like a U on the end. Looking at this -> U shape, there are two holes at the top. There is a metal pin that goes through these holes, and the pin is attached on it's end's, by the main body of the carburetor.
The flat metal U shape, and the metal pin, works together to form a type of hinge, allowing the float to pivot on it.
Where the U shaped hinge is attached, the float needle, clips to it.
The float needle has a tapered neoprene tip, and sits in a Float Needle Seat. This seat is a barrel shaped piece of brass, and has a tapered hole at the bottom. Fuel comes up through this seat, and the float needle regulates how much fuel can come in.
As the float drops down, it draws the float needle out of the float needle seat, and fuel comes in. As the float bowl fills with fuel, the float rises, and pushes the float back up, also pushing the float needle back into the float needle seat, cutting off the flow of fuel.
There is a specified height of the float, in relation to where the float sits in the float bowl. If the float sits too high, the float bowl fills up with fuel, and overflows. This overflow goes through an Overflow Tube, on the carburetor.
(If the float sits too low, the engine starves for gas)
A LOT of times, crud builds up in the gas tank, makes it's way through the fuel line, and gets into the float bowl. It can get in-between the float needle, and the float seat, thereby flooding the carburetor out, and fuel comes out of the overflow tube.
The float bowl is also attached to the carburetor with a brass main jet nut. At the bottom of the float bowl, this will look like a brass head of a bolt. Under the brass head is a small O-ring. This can leak. First step is too insure this is tight. (Do Not Over tighten! This is part of the main jet, and is expensive! It's Brass)
Where the outer part of the float bowl itself, attaches to the carburetor, there is another O-ring.
A large one. This O-ring, like the main jet O-ring, can deteriorate over time. Additives that gasoline has in it, heat from the engine, and heat from the sun does this. Plus just age. Neoprene breaks down after time.
It could also be that the neoprene tip of the float needle has broken down.
You indicated you adjusted screws on the bottom.
These are the Main Jet, and Idle Jet -> Air Mixture screws. All they adjust is how much air goes through these jets.
The amount of fuel going through, is predetermined by specific passageways, that are drilled through the main body of the carburetor.
This only comes into play when the engine is running. With the engine off, and fuel leaking out, you have crud under the float needle, or one or more of those O-rings has deteriorated.
May 12, 2009 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Garden Logo
73 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
