Question about Philips DA1000 FM Radio
Da1000 philips display
Displays no disc when Cd is player
Hello
Put it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.
The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
Jan 23, 2012 | Sanyo DC-DA1000 CD Shelf System
I want to buy a battery charger. Where do I purchase?
Hello
The external power adapter for your device is for [6VDC - 1 Ampere]. You can use any adapter with this capacity to charge the battery inside the your Philips Da1000. Brand is not matter, but the voltage and current is. Just check the DC socket polarity. It is the main thing that ahs to be checked. Some sets will have outer (+ve), and some others have (Outer (--ve). This will be marked at the DC in terminal of your radio. It is best to be the set in hand, when you go to buy a new one. This adapter can be bought from most of the electronic spare parts selling shops at your town. Philips has designated as [6V direct current, positive pole to current pin] as pin confuguration for the AC adapter. If so outer ring connection will be (--ve). Anyway, make sure about it before buying a new one. OK.
Aug 30, 2011 | Philips DA1000 FM Radio
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
Starts up fine, but randomly goes into protect mode after 7 secs..yesterday it worked all day with no problem
Please provide the model and maker of your device. It was easy to identify the problem.
Thanks
Oct 16, 2009 | Sony STR-DA1000ES Receiver
MY HUSBAND'S PHILIPS DAB RADIO SEEMS TO HAVE SELF-COMBUSTED! THE CASING HAS MELTED AND IS TOTALLY KAPPUT! PRESUME THAT IT MUST HAVE BEEN THE BATTERY, BUT LOOKS QUITE DANGEROUS
If its running through batteries then its probably due to rechargeable battery else if it runs through power cord connected to mains then its totally due to manufacturing fault.
Thankyou
Jul 31, 2009 | Philips DA1000 FM Radio
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Can only use the da1000 direct from mains
Do you mean you cannot use rechargeable batteries in this device ?
If you look at those supplied with the radio, you will see that the insulating sleeve on the battery itself does not fully enclose the battery at the negative end. Inside the radio's battery compartment you can see a metallic strip next to one of the spring terminals. This is no coincidence - if you wish to use your own rechargeable NiMh batteries you should be able just to take a sharp knife to the sleeve on your preferred battery and trim it back slightly. When the metal strip in the radio can touch your battery, it should work just fine (based on my experience).
Regards,
Garry Heather.
Dec 07, 2008 | Philips DA1000 FM Radio
On/off button
Try a cellphone repair shop in your area... I think they can have it fixed since they are similar to cellphone parts or small parts.
Oct 02, 2007 | Philips DA1000 FM Radio
Finding staions
U do have the correct h/phones connected as these r the arial?
Dec 27, 2006 | Philips DA1000 FM Radio
Philips DA1000 FM Radio Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
