Question about Garmin nuvi 200W GPS Receiver
Garmin 205W doesn't work while charging in car
I have a 205W with the same problem. It works flawlessly on battery power, but as soon as I plug in the car charger, the screen reverts to the icon showing it hooked into a PC. Then it will go to the Garmin screen, come on for a few minutes, and then shut down, and repeat the whole process.
Has anyone else encountered this?
I have a 205w and have been very frustrated with this same issue, but I just so happened to find the following fix on another site today and it works great.
Follow these steps:
Turn on the unit on battery, press the battery icon and hold for about ten seconds, and the unit will switch to the diagnostic mode. Now plug in the USB cable and it will give you a loud bleep. Exit the diagnostic mode and it will operate normally while charging. This was handy to enter favorites while it was charging.
Posted on Jul 20, 2009
Just got a used Garmin 205W in the mail with no User's Guide. It says low battery. Can I charge it with a regular plug in device like I use for my cell phone, or do I have to use the cigarette lighter...
You can charge the garmin satnav with either the car charger when the car is running, an optional mains charger or you can charge it through the USB port of a computer. It takes around 8 hours to charge through a computer or 4 from a car or mains charger.
You can get the user manual from http://static.garmincdn.com/pumac/2675_OwnersManual.pdf
Aug 03, 2011 | Garmin nuvi 205W GPS Receiver
My unit lost power mid trip and I haven't been able to get it to work since.
Your GPS battery may have drained its charge because your car charger is not working. Try plugging it into your computer with a USB cable. If it turns on you will need to replace your car power cord. If it still does not turn on your GPS may have a bad connection or something is wrong internally. You can try resetting it but take note that this will clear all your saved data in the GPS
Nov 16, 2010 | Garmin nuvi 205W GPS Receiver
How can i charge it if my car smoke thingy doesnt work?
Plugging your Nuvi into a computer's USB port will charge it. You can also use a powered usb hub that has a wall-power plug to act as a charging station for your nuvi without needing a computer at all.
Mar 11, 2010 | Garmin nuvi 205W GPS Receiver
Hi i have garmin nuvi 205w i was showing me ,accessory not suppor
maybe it is not charging
does the charging light come on?
both on the unit and on the car power plug.
does your cigarette lighter in the car power other things?
you can charge it with a mini-b usb cable connected to a computer.
Jan 14, 2010 | Garmin nuvi 750 GPS Receiver
Battery gradually discharges unless forced to charge
something is wrong withe your lighter so unplug it when the car is off also you may want to do a complete charging system inspection on your vehicle
Jan 06, 2010 | Garmin nuvi 205W GPS Receiver
205W doesn't give option for "Turn Off" or "Stay On" when ignition is turned off. Battery reads low when turned off manually.
have you checked charging using a usb lead on pc it will say charging on screen , as it sound like your power lead in the cigar lighter is not working, there is a fuse in it and it should light up
Jan 04, 2010 | Garmin nuvi 205W GPS Receiver
Why does my garmin nuvi 205w keep shutting off?
The most common cause is low battery.(no voltage to the unit)
Does it shut off if plugged in and not moved?
If you have a old battery it may show a full charge while having only a surface charge and of course....will shut off.
Also if it is plugged in and the connection is moved causing a bad connection .....even for a second while having a bad battery in the unit ....it will ...of course ....shut off.
Nov 03, 2009 | Garmin nuvi 205W GPS Receiver
Plugged device into car outlet. Device comes on, shows Garmin name and then shuts off and does nothing more. Prior to this happening screen displayed "battery low".
DC power will not properly charge the battery. It is possibly damaged. Change i. Preferably charge it via AC before using on DC.
But change battery....
Jul 05, 2009 | Garmin nuvi 205W GPS Receiver
Garmin 205 will not turn on or charge.
Have you tried to plug the unit into another car lighter socket? The battery may be dead in the unit and the charge cable could have a blown fuse or the cigarette light socket may not be working. Try plugging something else into the car and see if it works. If it does then try to plug the gps cord and gps into another car to see if it works. If not you may have a blown fuse in the plug. Unscrew the tip of the plug and change the fuse. Good luck.
Apr 03, 2009 | Garmin nuvi 205W GPS Receiver
Issues with new Garmin
Try pushing the reset button and charging again. If that doesn't work I think you've got a defective unit. Contact the seller and sendit back for a trade.
Apr 20, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
2,401 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
