Question about Tefal T-FAL FZ700251 Actifry Low-Fat Multi-Cooker, Black Best Deal $185.20
Lid not closing properly
Lid does not fit together and steam escaping
Oval lid, what is the correct fit, should it be a tight fit, or my just sits on top, there is a small space around.
You should have a fit that has a little wiggle room, including a little space around the edge of the lid. When you cook in a slow cooker, you'll make a bit of steam, and it needs room to escape. A super tight lid would likely end up 'burping', and possibly spraying spurts of whatever your sauce is, across your kitchen. Having that small groove there also leaves you a space where a bit of steam can condense and either trickle back into the pot to keep things moist, or just sit there in the gap and not drip all over your counter. Having a little bit of give also means that if you cook and let things cool, the condensing steam won't create a partial vacuum and leave you having to plant a foot on the side of the crock pot to pull the lid off (likely with more spectacular spew-age ready for viral videos).
Cheers!
Nov 06, 2015 | Crock Pots & Slow Cookers
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
Replacement
GLASS LID IS RECOMENDABLE.
Sep 22, 2013 | Wolfgang Puck WPDRCR10 Rice Cooker
Lid doesn't fit tight
put aluminum foil around lid and press onto pot this will help it make tight fit
Jun 12, 2012 | West Bend 84496 6-Quart Slow Cooker
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
My pressure cooker always makes a hissing sound. Is that close properly?
As long as the lid is properly locked into position it should be closed properly. A certain amount of air and steam will escape from the valve on the lid and will male a hissing sound but this is perfectly normal.
Jan 17, 2011 | Manttra 38131 8qts Stainless Steel
Hi, The lid does not fit tight.I thought the lid
No it does not need to be tight, excess steam needs to escape.
Dec 20, 2010 | Rival 3355 5-Quart
Why doesn't my cover fit tightly? 5.5 Qt Rival Crock Pot - lid does not fit tightly and hot water is bubbling and spitting out of the crock pot making a mess and an unsafe situtation...help! Is this a...
There's nothing you need to do differently except place the cooker where a little splashing won't hurt anything. This is typical of all crock pots. The cover fits loosely because it must allow steam to escape. When water turns to steam, it expands. If not allowed to escape, the steam pressure would explode the vessel. The simplest and cheapest way to let the steam escape is to let the lid lift freely. Some of the steam re-condenses into water as it escapes, and then it sputters and splashes as more steam comes out. They could make a more complex system to control the mess, but then a crock pot would be bigger, more expensive, and harder to wash. I know this might not be the answer you hoped for, but it's a truthful answer to your question so I hope you'll rate it accordingly.
Jul 16, 2008 | Crock Pots & Slow Cookers
Tefal T-FAL FZ700251 Actifry Low-Fat Multi-Cooker, Black Best Deal $185.20 Logo
493 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
