Question about Apple iTunes
My itunes does not start whwn i clicked on icon.
  • 355 Answers
Here's some info that may help - picked up from other boards where similar problems reported.
First check to see if Quicktime works normally, iTunes will not work without it.
If Quicktime is OK, then use these troubleshooting articles: XP version http://support.apple.com/kb/TS1421 Vista version http://support.apple.com/kb/TS1717
Have you installed any of the following: ACE & K-Lite mega codecs package, QT alternative, Storm codec, WinAVI video converter, Mpcstar, (possibly starcodec pack, 3ivx)
If so uninstall them, they are know to cause problems with Quickitme. Then download the version of Quickime without iTunes: http://www.apple.com/quicktime/download/win.html Now Remove Quicktime using the method for Quicktime in this article (just Quicktime): XP http://support.apple.com/kb/HT1925 Vista http://support.apple.com/kb/HT1923 When you come to your C:\Windows\system32\ folder you can delete any file or folder with Quicktime in the name. Restart you computer Install the stand alone Quicktime and check if it starts. If it does you are in a position to find out if iTunes is OK.
If Quicktime is OK, do you get any error message when you try to start iTunes? If not, open your task manager after trying to start iTunes. Do you see iTunes.exe running on the processes tab. If there is no error and you see iTunes.exe running then iTunes is hanging and we need to look at a slightly different route.
Sometimes it is just a problem with the itunes database file when it won't open after an upgrade. Press and hold the shift key while trying to start itunes. Does it give you an option to choose or create a new library? http://docs.info.apple.com/article.html?path=iTunesWin/8.0/en/15502.html
Bonjour is a common cause of iTunes hanging at start up. i.e. silent launch failure with iTunes.exe running on the processes tab. You can uninstall bonjour if you don't need it. However it is required for sharing libraries and other things
You could also try uninstalling it, then downloading bonjour from Apple and installing it directly. http://support.apple.com/downloads/Bonjour_for_Windows
Posted on Jun 15, 2009
  • 11,896 Answers
Try reinstalling the software. Also make sure downloaded software is completely updated. If you have a firewall, make sure it is not blocking itunes.
  • surf_koa Oct 17, 2010
    i just uploaded the lastest 10.0.1.22 version of iTunes and worked fine for a day tehn stopped. i am using a HP Mini w/ Windows 7 Starter. For the past day and a half I could nto understand why iTunes was not working, possibly the computer couldn't handle it. Turns out the problem was BONJOUR. I did not have to completely unistall, instead go into the Services when you launch Task Manager, there you will see Bonjour running, stop the Bonjour service and iTunes should pop right up. Providing the problem you are expeincing is Bonjour. This is an easy fix and I would suggest tryign it first before performing anything more invasive.
  • Nate Stansfield
    Nate Stansfield Oct 18, 2010
    You can update bonjour and it works fine with it.
Itunes will not open on my pc
try using itunes through the start menu, if this works the shortcut is the fault. delete shortcut and make a new one.
if this still hasnt worked delete the exe. file for itunes and download itunes again
May 25, 2012 | Apple iTunes
How to trun on genius
How to Turn on Genius
The iTunes Genius feature suggests and recommends new music, movies, and television shows based on your device's music library and playlists. The Genius feature can automatically create new playlists for the user to enjoy and will do so based on the different genres and styles of media already present in the library. Using Genius, you can discover new music that's interesting to you.
Instructions
1Open iTunes on your computer.
2Click the "Store" menu link then click "Turn on Genius."
3Click the "Genius" entry in the iTunes sidebar to the left then click "Turn on Genius."
4Select a song in your iTunes music library and click the Genius icon located at the bottom of iTunes. The icon is represented by an atom.
f you are using iTunes for the first time, you will see Genius listed on the left side of the iTunes window above Playlists. Click Genius and then click Turn On Genius to start using Genius. You can also start Genius by choosing Turn On Genius from the Store menu in iTunes, or by selecting a song from your library and pressing the Genius button at the bottom of the iTunes window.
When starting Genius, you'll be asked to sign in with your Apple ID or create a new one and agree to the terms and conditions.* iTunes will then proceed to gather information about the contents of your library, send this information to Apple, and download Genius results. The time to complete this process will vary depending on the size of library information and the amount of traffic on the iTunes Store. At any time during this process you can use iTunes to play music or other content.
To turn off Genius, simply choose Store > Turn Off Genius in iTunes.
Jan 03, 2012 | Apple iPod mini 2nd generation MP3 Player
Pleas help my, I install I tunes 10 on windows 7, after that all icons on desktop get itunes loco, and itunes opens if you click it
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Dec 21, 2010 | Apple iTunes
We have a new computer and are running window 7, when i click on the itunes icon it will not open? ta
Click Start, type regedit, then press Enter. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers Its better you clean/repair Windows registry with RegInOut. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Sep 27, 2010 | Apple iTunes
Have downloaded itunes but it will not work when i click the itunes icon nothing happens
I would un-install the program and start from scratch. Download the itunes package from apple once again and start over. hope this helps
Apr 20, 2010 | Apple iPod MA446LL/A MP3 Player
All icons open itunes has something to do with the
Open up Finder, navigate to the file in question and right-click it to bring up the contextual menu. Select Get Info and then from the box that appears you'll find, about halfway down, the heading Open with: Click this and you'll see the default app associated with this file type.
Jul 11, 2017 | Toshiba 50H82 50" Rear Projection...
No audio when i try to play tunes in itunes
FIRST try the simple solutions. Check if your speaker wires are plugged into the proper ports.
If you are unsure, it won't hurt to try different configurations.
(If you hear sound from other devises such as plating a CD of the "Microsoft Sound" when starting up or shutting down, then the speakers are wired correctly.)
If this is OK then try...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Sound video and game controllers"). If there is some kind of a "Warning" icon superimposed on the 'speaker' icon there is your problem!
If no "Warning" icons then try...
One at a time...
Double click on each of the devises that have 'Audio' in the listings.
Click the "Properties" tab, look for any "Warning" icons
Uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Oct 23, 2007 | Adobe Photoshop 7.0 for PC
Apple iTunes Logo
9,112 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
