Question about Nokia (BL5J) 5800N900
Internet acces with wlan
I have a weird problem with my switch . It doesn't give me internet acces when i try to connect my pc with it but when i connect a router to the switch it does work . I tried everything : restarting my...
Do your service provider limits number of ip address (10.10.10.10) you can have? if they provide only one, you would need to use a router to share one public ip address. Sometimes it records the network address of your network device (00:00:00:00), and won't give u another ip if the device changed. If you have two routers in your network, turn off the dhcp on the second router, and use LAN ports and do not use the WLAN on the second router. if you want to manage the second router, give it an static ip from the first router. Bad port? Bad cable? Modem => router => PC/IPOD/switch or modem => router => PC/IPOD/Switch/ 2nd Router without dhcp and no WLAN ) Good luck
Jun 16, 2017 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
If the WLAN light wont come, first thing that you can try here is to reset the unit again, by pressing the reset button for 10 seconds to correct the problem and once you're done resetting the unit unplug power for 10 seconds and then check if the wlan light is back....
Dec 01, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
My computer is saying connected to router but no internet and my cable light on the router is not lit. (yes the cable is active on my tv) Any suggestions on the problem and a solution
if its the first time you connected the router ...you have to make the wlan connection ..and clone the Mac address on the router to fit the old mac that u had on computer card..
this in case ia have a static ip address and you need to make the internet connection with the provider... after that select from your pc network setting to obtain an ip address automatically ...and you put the sub-net mask at 255 255 255 0 and the default gateway as the ip address of the router ...
do not forget the router is now your connection with the provider so there is where you set the provider 's settings ...
if you have a modem too just select at the wlan in the router .to obtain an auto ip ...and in the computer too ..you may also clone the mac adress cause the provider may have it ..and block the acces cause didnt recognize the new one (router's Mac)
Jul 30, 2009 | Linksys WCG200 Wireless Router
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Need to connect IP phone via laptop
I use a usb internet phone which before use I had to install from setup disk which came with it but many net phones just plug into modem but Im sure they have some kind of software for them.try google and look for drivers
Dec 17, 2008 | Compaq Armada E500 Notebook
Wifi not working
Your WiFi works only if your phone is in a WLAN network.Select Menu>Tools>WLAN Wizard.The phone will automatically search for availiable WLAN networks.Select the desired network.Click Options>Start Web browsing.The phone will automatically create an acces point and you can browse the internet.
Sep 16, 2008 | Nokia N81 Smartphone
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Connecting to wireless internet on psp
http://www.us.playstation.com/Support/PSP/ConnectingToInternet/default.html copy and paste this location on the internet and follow the instructions for tha kind of troble the one you have but i think the problem is because the acces point is locked fixya rate
Jan 05, 2008 | Sony PlayStation Portable (PSP) Console
Nokia (BL5J) 5800N900 Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
