Question about Samsung HT-X200 Theater System
Will not read a disc and says no disc
When trying to play a disc it says no disc is in
No disc message
1 - Try a different disc.
Either works, or not.
If works, problem original non-playng disc.
If not working, problem is player (or another faulty disc).
2. If player is problem:
Try using a 'head-cleaner' disc (from store).
These usually play whilst cleaning.
If no play - problem is 'read head' in player.
If it plays, then try ( a known good - works in another machine), disc.
3. If 'read head' is faulty, you need a techy to replace, or throw it away, buy a new one (more likely).
Rafe
'Live long and prosper'
Sep 07, 2013 | Craig CVD327 DVD Player
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Why wont my xbox 360 elite read discs? i put disc in and it comes up reading and then open tray
My only questions are does the console say the discs are damaged in any way? and is the console standing up right?
If the discs are scratched in any way then that might cause the 360 to not read the disc and sometimes having a console play the disc upright (example of upright 360) for a long time can cause dis function when trying to play discs, so try playing the discs with the console on its side (side example) These are my solutions to the problem but you can try these: Solution 1 Solution 2
Mar 13, 2011 | Microsoft Xbox 360 Elite Console
Dvd disc not reading
Is it just that disk or are all the discs not reading?? If it is just that disc try cleaning the disc with a lint free soft towel. Also is the disc a factory dvd or a burnt copy of media. Some dvd players will not play certain re-write discs some play DVD-R and some play DVD+R and some will play both ... good luck
Oct 19, 2009 | Audio Players & Recorders
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
WHEN I TRY TO PLAY A PLAY STATION 2 GAME IT WILL READ THE DISC THEN AUTOMATICALLY STOP READING THE DISC
i had this problem its 1 of 2 things your engine is on its way out or your laser is on its way out take it to a console repair shop to get it repaired
Apr 30, 2009 | Video Game Consoles & Games
Disc drive does not read or play discs
clean the lens and then try again if not
Change the disk drive maybe your disk drive lens has gone
Apr 21, 2008 | Acer Aspireā„¢ T180 PC Desktop
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Samsung HT-X200 Theater System Logo
74 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
