Is the motor on the turntable spinning - wiring misconnected?
If motor is running then th epower is not being transmitted to the platter by either a belt drive or a pulley drive.. The belt or pulley has to be replaced to restore the missing friction
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
