Question about kawasaki 2012 Jet Ski Ultra 300X
My jet ski keeps beeping and says HEAT
Why does it keep beeping and say HEAT?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • kawasaki Master
  • 1,190 Answers
Is the engine and exhaust hot when this happens ?
if not then have the heat sencers checked , if yes then check thermostat and cooling hoses for blockages !
Posted on Apr 03, 2014
My jet ski Yamaha 1200cc / year 2001 X L . Beep because it overheat
It may not be pumping enough water thrue to keep it cool.check for blockage also.
Apr 16, 2017 | Yamaha Cars & Trucks
Polaris troubleshoot
clean impellor and water intake ! run up on hose and check cooling ok !
Jul 28, 2014 | WSM 1993-1994 Polaris Sl 750 Cc Jet Ski...
Jet ski smoking
what colour smoke , correct fuel ??
Jan 04, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
What is the difference between a powerboat and a jet ski?
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Jan 17, 2013 | Boating
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
1998 kawaski jet ski that boggs down on take off
Sounds like this bike sat for a while. When carburetors sit, the jet's inner diameter shrinks slightly from oxidization/micro-corrosion, and the diameter of the needles that go through them grows for the same reason.
Replace the jets and the needles that go through them.
I had this problem with a Suzuki GS850. When I fixed it, I treated the bike as I had been before I fixed it on the test drive, and almost launched myself off the back of the bike when I first opened the throttle. Careful.
Jul 08, 2010 | 1998 kawasaki GPZ 1100
PlZ PLZ HELP kawasaki jet ski with fuel issues
Take your carburetor apart and clean it. There is moisture corrosion that is keeping the needle from moving. Be careful not alter the little teeter totter spring in any way.
May 15, 2010 | Encore Software Kawasaki Jet Ski...
Jet ski will not run at full throttle
Check for holes in the diaphram the pulses the needle and seat in the carb.
Jul 23, 2009 | Sport & Outdoor - Others
Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
Jul 05, 2009 | Yamaha 12V Air Pump
kawasaki 2012 Jet Ski Ultra 300X Logo
378 people viewed this question
Top kawasaki Boating Experts
J.D. Browning
J.D. Browning
Fabrice Wolters
terry stevens
Are you a kawasaki Boating Expert? Answer questions, earn points and help others
