Question about Moultrie I-45 Digital Camera
The camera will not starts to turn on and than shuts off
Camera will not turn on
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
My polaroid i1037 camera shuts off immediately when it is turned on. It starts to turn on, then the screen shows the word "goodbye" and then the camera shuts off. I have tried new batteries several...
they're usually very reliable but if yours broke maybe you should checkout www.justdeals.com theyve got the i1037 for 40 dollars plus fast free shipping
Oct 19, 2010 | Polaroid I1037 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
Record Beep Tone - How To Shut Off
On the Mino HD, Hold down the record button as you turn the camera on. Navigate the menu and turn off the sound under the sound option.
Mar 31, 2009 | Pure Digital Flip Video Ultra Camcorder
Shuts off after turning on
Try changing out the batteries or charging the camera,also with a digital camera they will kill ordinary alkaline batteries I suggest using e titanium
Dec 25, 2008 | Fisher Price Fisher-Price L8341 Digital...
Digital camera starts then shuts down
yeah its broken sorry mate
suggest a new camera
Dec 15, 2008 | Cameras
Fuji S5000 Shuts down
Battery problem, might need new rechargeable battery as old one can't hold charge no more.
Nov 06, 2008 | Fuji FinePix S5000 Digital Camera
I turn camera on and it shuts off immediately
I had the exact same problem, it would shut off after trying to turn it on. The door to the memory card has very small tabs on it that push in some kind of sensor inside the camera when you shut the lid. It starts up when I push in the sensor.
Mar 24, 2008 | Fuji FinePix S3000 Digital Camera
Cyber-Shot DSC-S500
We had similiar problems with ours until we started making sure the camera was kept warm when it was shut off. For some reason, it and the batteries don't like the cold...we were able to extend the battery life if we kept it covered when we weren't using it.
May 10, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Moultrie I-45 Digital Camera Logo
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
