Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
No power dc1200
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
I have a Sealife dc1200 camara. On my last trip moisture from the rinse tank, clean water, got into the housing. Blow dryed it right away. Removed battery and card. Now will not turn on. Can it be saved?
The camera is depth tested to 200 feet so the pressures exerted with flowing water in a rinse tank I wouldn't thing could exceed those pressures. Is this maybe a warranty thing I'd check first before doing to much more and possible voiding any warranty.
I've had mild success after overturning a canoe with some of my gear buy placing it in a container of uncooked rice. The rice actually draws the moisture out I'm still after two years using the camera but my flip phone bit the big one after the trip, I suspect because it was on and active when it hit the water.
Also I would be looking at the seals around the battery compartment and door to the memory card because something isn't right. All it takes though is a little dirt on one of those seals to wick the water into the camera.
Another thing is an atmosphere change as in temperature if the rinse tank water was hot after bringing the camera up from a colder depth you would create a condensation problem almost instantly.
I would also suggest that you clean the battery contacts well with the eraser end of a new pencil more polish then scrub, the eraser will remove oxides that will form on the terminals. Clean both the battery and the battery compartment.
It might not be a seal it might have been the temperature of the rinse tank that caused the problem. If nothing works then the only thing I'd suggest is retuning it for a service. What also will happen in a condensation situation is there will be water spots on the inside of the lens and there is no way except dismantling it that will clean that off.
The camera is worth the service, I have see it listed at around $800.00 I can't see the service being much more then $150.00. That's if the cleaning of the terminals and the rice didn't work.
Cheers best of luck with that
Feb 16, 2011 | Cameras
Sealife DC1200, I have 2 brand new and after I put in a SD card it gives a card error?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 17, 2010 | SeaLife DC1200 Digital Camera
Instructions for coffeemaker cuisinart DC1200 need to know how to set the automatic time for cooffemaker
Turn dial to PROG
Press and release HR button a few times - it will have a "PM" on the display if it is set for PM
Press and release MIN button until minutes are set
Once the time you want it to go off is selected, turn the function knob to AUTO-ON - flick the switch to ON - a green light will now illuminate and you are ready to go (don't forget to put water in the reservoir and coffee in the filter basket)
Sep 24, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
DC1200 coffee maker when I flip the switch to brew nothing happen
Your switch has shorted and it's time to get a new one. There is no way to fix this and frankly, it will cost more to fix it than to just buy a replacement. Sorry for the bad news!
Feb 13, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
24 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
