Question about T-Fal Avant? 4-Slice Toaster - Chrome
Lever on 2 slice T-fal Avante toaster won't stay down
Tried different outlets in case first outlet had a problem, but lever will not stay down no matter where it is plugged
2 Suggested Answers
  • 333 Answers
SOURCE: lost manual for T-Fal Avante Elite convection oven 028085002
Follow this link and it will have what you need. I hope this helps you.
Posted on Nov 30, 2008
My paper white kindle can't hold a charge,no matter how many different outlets I try..
Contact amazon and say it is faulty and that you need to return it, they should replace / repair as it is less than 1 year old.
Aug 30, 2016 | Amazon Tablets & eReaders
I plugged a 30 amp power supply cord from an rv to a 15 amp house outlet to run a/c to rv . gfci tripped and wont reset. damaged gfci or something else?
A GFI outlet works independently of sensing an overload condition. Overloads are dealt with by the circuit breaker or fuse in your electrical panel. The GFI simply compares the current on the hot terminal (black or red wire) with the current on the neutral terminal (white or gray wire) and interrupts the current if there is more than 5mA (0.005 Amps) difference between the two.
Remove the load - in this case the RV plug - from the GFI outlet and attempt a reset. Make sure you're pressing the RESET button and not the TEST button. If it resets - you're all set. Reconnect the RV plug to a different outlet - preferably NOT a GFI type.
If it still wont reset, it is important to know that GFI outlets can be wired in such a way that any circuit extended to other outlets (lights, too) via the LOAD terminal screws will also be protected by the GFI. We need to be sure that there wasn't something else causing the fault. Check other nearby outlets for functionality. Remove plugs from any outlet found not working and attempt to reset again.
If it will not reset - it is possible that the internal sensing circuitry has been damaged due to such a large amount of current trying to pass. In this case, replacing the GFI outlet will be needed.
Oct 09, 2015 | Washing Machines
Lever won't stay down. Have removed all screws and could take off top but handle on lever prevents this. How do I remove the end of the lever in order to get the top off to check latching mechanism?
My toaster turned out to have an electromagnet that makes its lever and the toast carriage stay down. It turned out that the problem with my toaster was that it was plugged into a faulty outlet. Unfortunately, I destroyed part of my toaster's darkness mechanism trying to understand its latching mechanism before I realized that it was not made like traditional toasters. So my first recommendation to you: try plugging it into an outlet that you KNOW works.
Feb 13, 2015 | Kitchen Appliances - Others
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
Steady Yellow Light
Is it an old model? Should you try to have it replaced?
May 18, 2017 | Holmes Products BH3955-U Bionaire Utility...
T-Fal Avant? 4-Slice Toaster - Chrome Logo
87 people viewed this question
Top T-Fal Kitchen Appliances - Others Experts
Ruth summersides
ray gallant
Are you a T-Fal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
